| This is a discussion on New Problem 2008 Pruis; Have This Ever Occured to YOU? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I had driven about 3 miles, parked the car for about 45 minutes and started home. First indication "something" wasn't ... |
| Junior Member Join Date: Apr 2008 Location: Venice, FL
My Car: 2008 Prius Model: Package: #3 Touring Thanks: 6
Friends: 0 | I had driven about 3 miles, parked the car for about 45 minutes and started home. First indication "something" wasn't right was the cruise control would not set at any speed. Second indication was that when I tried to "glide", it felt like I was applying the brakes; the car didn't glide (roll) like it should. When I got home, I shut the car down, waited a few minutes, started it up again and everything seemed to be normal on a one mile test drive. When the above problem was observed, no warning lights or abnormal indications on the display. I have a scan tool and zero errors were indicated? Any ideas??? |
| Senior Member Join Date: Jun 2007 Location: Connecticut, USA
Friends: 0 | If you have that again, check and make sure you're not in [B]. Had the same symptoms and that was the issue... I had bumped the shift nob. |
Friends: 0 | Thanks for that suggestion. Think you are right. I may have bumped the shift lever after the initial change from park to drive |
Friends: 35 | I would be willing to put money on the above answer. You accidently put it in or left it in B. Just another reason why I rarely ever use it. |
| Senior Member Join Date: Oct 2007 Location: Gilbert, AZ
My Car: 2008 Prius Model: Package: #6 Thanks: 1
Friends: 1 | Quote:
| Senior Member Join Date: Sep 2007
Friends: 0 | you're also wrong, he will get regenerative brakes in that mode more than if he was in D on a level road... but it is not the max amount... He won't get ZERO regenerative braking... unless his battery is already Full green. |
Friends: 35 | Quote:
LOL Sucks that the original owner wasted so much fuel driving it that way. | |
Friends: 1 | Quote:
| C'Mere Sheepie! Join Date: Mar 2008 Location: Sanford FLorida
Friends: 6 | I havent had that problem but I did have a problem driving mine when I first got it. My wife kept stealing it! I finally solved it by letting her go get one of her own. |
| 2008, occured, problem, pruis;, you? |
| Is the oil overfill still a problem for 2008 models? | mikem13 | Gen II Prius Care, Maintenance and Troubleshooting | 15 | 06-02-2008 12:12 AM |
| My problem with 2008 prius, help | caroleyang | Newbie Forum | 7 | 03-22-2008 07:59 AM |
| Still waiting on my 2008 pruis.. | sandman | Newbie Forum | 6 | 03-19-2008 11:33 PM |
| Problem with Coastal Lockpick and 2008 | wolverine | Gen II Prius Modifications | 0 | 02-13-2008 08:27 PM |
| Success That Hasn't Occured Yet | Beryl Octet | Fred's House of Pancakes | 14 | 12-31-2006 02:51 PM |
