This is a discussion on Extended warranty expires soon! within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; My extended warranty will be running out this fall and was wondering what I should be checking out before it ...
Old 08-10-2008, 08:05 PM   #1
Weinerneck
Default Extended warranty expires soon!
My extended warranty will be running out this fall and was wondering what I should be checking out before it expires. I have a 2005 which just turned 3 years old and just shy of 90,000 miles. We have replaced both front hub assemblies and had a little trouble with water getting in the coil pack tubes. Other than that it has been a pleasant 90,000 miles of driving.
I hate going to dealers for service but was thinking it might be worth having them looking it over before the warranty runs out, any thoughts?
I did just change the transaxle oil myself (dealer said it needed it) and have done most of the oil changes, filter replacements and little things myself.
Any concerns, thoughts or dealer recommendations I should heed or be wary of?
Weinerneck is offline
Old 08-11-2008, 09:43 PM   #2
Sheepdog
C'Mere Sheepie!
Sheepdog's Avatar
Friends: 6
Default Re: Extended warranty expires soon!
what caused the front hubs to go out? That would be expensive I bet without coverage. At what miles did they go?
Sheepdog is offline
Old 08-12-2008, 12:03 AM   #3
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
Originally Posted by Weinerneck View Post
My extended warranty will be running out this fall and was wondering what I should be checking out before it expires...
  1. MFD - has it ever acted flaky?
  2. Inspect front struts and rear shocks, looking for oil leaks. If leaks are more than minor, you may be able to get them replaced under warranty (a fairly expensive repair post-warranty)
  3. Air conditioning - does it quickly cool down a hot passenger cabin?
  4. Any problems with the stereo system or CD changer?
  5. Exhaust system - check physical integrity (rust, holes, etc.)
  6. Brake system - if covered under extended warranty, inspect front disk rotors/pads and rear drums/shoes
Patrick Wong is online now
Old 08-19-2008, 05:46 PM   #4
Weinerneck
Not sure what made them go, right front went at 73,000 and the left a few thousand later.
Sheepdog- Protecting my flock
2008 Barcelona Red "Lil Rachel"
Avg 56mpg for July08! A Greyhound in the back seat can't hurt!
Mods:
Rear Bumper Pad, Hood Deflector, No Reverse Beep, Garmin 660 GPS unit,
Zaino and Aerospace 303, wheel rings gone, Scan Gauge II, tire inflation at 42/40, PriusChat decal!
Click the image to open in full size. Click the image to open in full size.
Old 08-19-2008, 05:53 PM   #5
Weinerneck
Patrick......... I hesitate to say that the MFD, Stereo and the AC have worked fine. I'll look over the exhaust, struts, shocks and brakes before the big 100,000.
Thanks
expires, extended, soon!, warranty
Extended warranty... sea-horsea Gen II Prius Main Forum 48 03-17-2009 12:43 PM
Extended Warranty: What do you really get? paulrubin Gen II Prius Main Forum 17 08-26-2007 08:03 PM
extended warranty ELI Dealers & Pricing 2 12-04-2006 12:50 PM
Extended Warranty grandparuss Gen II Prius Main Forum 4 09-23-2006 01:20 PM
Anyone use the extended warranty yet? mcbrunnhilde Gen II Prius Main Forum 1 05-30-2006 03:20 PM
