| This is a discussion on 2005 Pruis Rear Wiper Replacement within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; The 2006 procedure implies I reuese harness and only replace blade. I purchased blade from dealer as not local auto ... |
#1 |
| Junior Member Join Date: Jul 2008 Location: Virginia
My Car: 2005 Prius Model: Package: #2 Thanks: 2
Friends: 0 | The 2006 procedure implies I reuese harness and only replace blade. I purchased blade from dealer as not local auto parts had one. Now, How do I remove the blade from the arm? Jetsfan_00 |
My Car: 2007 Prius Model: N/A Package: #4 Thanks: 57
Friends: 46 | Its not easy to remove the wiper blade from the arm. Rather than risk breaking it, I just removed the rubber from the rear wiper while in place. |
| übergeek Join Date: Sep 2007 Location: Mesa, AZ
Friends: 9 | When I changed mine out, I just removed the rubber insert without removing the wiper blade assembly. If you lift the wiper blade off the glass a little (not too far) you can bend the rubber insert down and guide it around the retaining tab at the end of the wiper blade. Then just pull the rubber insert out. |
| Senior Member Join Date: Oct 2007 Location: Gilbert, AZ
My Car: 2008 Prius Model: Package: #6 Thanks: 1
Friends: 1 | Unless the Prius is different than other cars it should be easy to get the entire blade off. You should just have to lift the blade off the window, then with a firm motion give it a push down on the arm and it should release. I don't know how else to describe the process. Perhaps someone else can put it in words better. Once again that's how all wipers I've ever replaced are done... not sure if the Prius for some reason is different than most. |
My Car: 2009 Prius Model: Package: #5 Thanks: 1
Friends: 0 | The procedure with pictures is on John's site at John's Stuff - Toyota Prius and more. Look at Prius Info > Wiper Blades. Last edited by firepa63; 08-16-2008 at 03:41 PM. |
Friends: 0 | To all, It may be simple, but not apparent. I change the front blades every 10K miles. Right now I have 90K on my 05 purchase late Dec 04, after my 92, 4 cyl Camry was totalled with 250K miles. Only Pruis in the area. I decided to just replace the blade and re-use the arm and blade assembly. I think the hard push down might work. Next time I will just purchase the re-fill blade and not the blade and holder. |
| Junior Member Join Date: Sep 2005 Location: Central California
Friends: 0 | To change rear wiper blade, first remove cover where wiper arm attaches to car tilt arm up from window. Grasp lower end of wiper blade and pull it away from arm (about 45 degrees) then lift blade up and out from arm. Bill |
| & troubleshooting, care, maintenance |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/52342-2005-pruis-rear-wiper-replacement.html | ||||
| 2005 Pruis Rear Wiper Replacement - Latest Toyota Prius News - Toyota Prius: Blogs and News - Newsbeet | This thread | Refback | 02-01-2009 06:24 PM | |
| Rear Wiper blade replacement | efusco | Gen II Prius Care, Maintenance and Troubleshooting | 19 | 12-27-2009 02:18 PM |
| rear wiper | lenjack | Gen II Prius Main Forum | 20 | 03-10-2009 04:03 PM |
| Anyone find larger replacement blades that work with stock rear wiper arm? | Snagtooth | Gen II Prius Care, Maintenance and Troubleshooting | 2 | 10-04-2008 03:51 PM |
| Why Does the rear wiper do that? | Sheepdog | Gen II Prius Main Forum | 10 | 04-22-2008 02:51 PM |
| Will They Fix The Rear Wiper? | Smooth Operator | Gen II Prius Main Forum | 19 | 07-19-2006 08:57 PM |
