| This is a discussion on New smart key problem within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; The part of the fob that starts the car via the slot in the dash is a passive RFID device ... |
| | #31 |
| Senior Member Join Date: Jul 2008 Location: Central Coast California
My Car: 2008 Prius Model: Package: #2 Thanks: 14
Friends: 0 | The part of the fob that starts the car via the slot in the dash is a passive RFID device that is queried by the car. No battery is required in the fob for the car to start via the slot. |
| | #32 | |
Friends: 44 | Quote:
Yes, there is a battery in the fob, CR2032, which you can buy at any drugstore for ~$5 or less. If you insert the fob into the slot, then the battery is not necessary. Use the mechanical key hidden in the fob to open the driver's door lock if necessary. You have to push very hard to get the fob cover off, while holding the release catch with one hand. Once you get the cover off, subsequent attempts will become easier. You will need a very small Phillips screwdriver to remove the small screws that secure the battery cover and become visible after you've removed the fob cover with your fingers. (Radio Shack sells a suitable set of small screwdrivers, I think the 2 mm size will work here.) Last edited by Patrick Wong; 11-04-2009 at 10:11 PM. | |
| | #33 |
Friends: 0 | A small flat screwdriver or awl can be useful for prying, to help start the fob cover sliding off (and remember that it *slides* off parallel to the long axis of the fob, it does not lift away from the body of the fob). |
| | #34 |
| Junior Member Join Date: Nov 2009 Location: Modesto, CA
My Car: 2005 Prius Model: N/A Package: Navigation Thanks: 0
Friends: 0 | Thanks to all who replied. I took the key in to service and the girl who came out to greet me took the cover off slick as a whistle. I couldn't believe it. I tried to get the cover off again and couldn't do it. I then discovered that you have to press on the emblem, and not above it. Anyway, I took it to the parts department and the clerck replaced the battery free of charge. But, I'm glad to know that a battery isn't necessary if the key is in the slot. So, for now, everything is going great. |
| | #35 |
| Sapphire of the Blue Sky Join Date: Apr 2007 Location: Virginia
My Car: 2007 Prius Model: N/A Package: #2 Thanks: 3
Friends: 0 | The trick to sliding off the battery cover is the release for the manual key. Keep it open, and then slide it off. there's nothing under the emblem that holds it. |
| problem, smart |
| 2006 Smart Key Problem | chrisky | Gen II Prius Care, Maintenance and Troubleshooting | 45 | 10-03-2008 10:51 PM |
| Smart key caused me a problem today | tydaco | Gen II Prius Main Forum | 24 | 05-20-2007 06:33 PM |
| My Smart Key Problem - -Help | Nicole | Gen II Prius Main Forum | 7 | 05-19-2007 09:49 PM |
| Minor Smart Key problem = ECU Replacement | hill | Gen II Prius Main Forum | 25 | 03-25-2006 05:20 PM |
| smart start/ smart entry | Buc | Gen II Prius Care, Maintenance and Troubleshooting | 7 | 05-27-2005 11:22 AM |
