| This is a discussion on New smart key problem within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hello all, my smart key has quit. I didn't find quite this problem, so I hope it isn't a duplication. ... |
| Junior Member Join Date: Aug 2008 Location: California
Friends: 0 | Hello all, my smart key has quit. I didn't find quite this problem, so I hope it isn't a duplication. Had the car two months, got in today and got the amber key and exclamation light. Car won't start without key in dash, doors won't open automatically, doors won't lock with the door button. The under-dash button was tried to no avail. Doors don't respond with the fob buttons to lock or unlock. The fob red light comes on, so should I try a battery anyway? I am taking it in to the dealer tomorrow unless I get a fix here. Both fobs same way, like something blocking the signal. Help!
__________________ Having so much fun with my 1st Prius! 2008 Seaside Pearl/Pkg #5 / XM Radio Wheelskins Two-tone Euro Leather Wheel Cover LoJack Uninstalled / Cargo Net |
| Senior Member Join Date: Oct 2005 Location: Northampton, MA, USA
My Car: 2005 Prius Model: Package: #3 Thanks: 2
Friends: 1 | Hmmm. Weird. All of your problems are consistent with something wrong with your fob. Have you tried your second fob? Even though the light is on, I might be tempted to try a new battery; it's cheap and easy to replace and you don't have to deal with the dealer. There's no way that a 2 month old fob should have a dead battery, but I'd still start there to see if that fixes it. If your second fob doesn't work either, than that points to a system-wide problem with the SKS; definitely something your dealer should fix. If only one fob works, then that suggests a problem with the other fob; also something your dealer should fix. But I'd try the battery first. . . |
Friends: 0 | From what you described, my guess is that the central unit of SKS has failed. You need to bring it to the dealer. P.S. Central unit is the electronic unit that collects inputs from all SKS sensors (3 exterior, and 2 interior) and grant various accesses. |
Friends: 0 | Ouch, hope they don't have to tear it apart for that! I should have stopped on the way home today for a battery, too late now. Both fobs are involved, so it would seem system wide. Glad it still starts to drive anyway. Ah, the wonder of computers! Thanks for your input. |
Friends: 1 | If both fobs are affected, I would think it has to be something significant with the car (and not the keys). The fact that the fob lock/unlock buttons don't work is pretty significant; this suggests that it's something beyond the SKS button being turned off (or some other small problem). I suspect that this is something that the dealer will have to deal with, unfortunately. |
My Car: 2006 Prius Model: Package: #7 Thanks: 94
Friends: 10 | Have you tried it at a different location? Radio interference would prevent both keys from working. Tom |
Should I suggest checking the central unit for the SKS? They would sure wonder where I came up with that! Surely they will be able to fix it. | |
Friends: 10 | Sure, they will be able to fix it. If it is the main SKS controller, yours wouldn't be the first to fail. Tom |
Friends: 0 | That is good to hear...we had an Excursion that had issues for 4 or 5 trips to the dealer, finally found a sensor that was malfunctioning. Wouldn't post a code in the computer, they had a terrible time. I hope this resolves itself quicker than that, like tomorrow! I'm driving my husband's Camry hybrid, but I miss my little car. |
Friends: 0 | So two days into diagnoses...still nothing. A SKS ecu (I believe) on order, should be in tomorrow and we'll see. They do have another prius there to "borrow" from to try other things he said if the ordered ecu doesn't cut it. The plot thickens. |
| problem, smart |
| 2006 Smart Key Problem | chrisky | Gen II Prius Care, Maintenance and Troubleshooting | 45 | 10-03-2008 10:51 PM |
| Smart key caused me a problem today | tydaco | Gen II Prius Main Forum | 24 | 05-20-2007 06:33 PM |
| My Smart Key Problem - -Help | Nicole | Gen II Prius Main Forum | 7 | 05-19-2007 09:49 PM |
| Minor Smart Key problem = ECU Replacement | hill | Gen II Prius Main Forum | 25 | 03-25-2006 05:20 PM |
| smart start/ smart entry | Buc | Gen II Prius Care, Maintenance and Troubleshooting | 7 | 05-27-2005 11:22 AM |
