This is a discussion on Where do you buy your parts? (oil, filters, etc.) within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Greetings Prius Family! I'm coming up on my first oil change and am planning on performing this task myself. My ...
Old 10-15-2008, 04:54 PM   #1
Weirdo23
Weirdo23's Avatar
Question Where do you buy your parts? (oil, filters, etc.)
I'm coming up on my first oil change and am planning on performing this task myself. My question is:
Has anyone found a reliable, inexpensive source for Toyota parts?
I'm checking with my local dealer to see what they want for the filter and drain pan gasket.
I've searched the site and come across www.metrotpn.com but shipping for 1 filter is over $10. It would probably take quite an order to make up for that...
Just thought I'd see if any of y'all have a few great resources to share.
Thanks in advance!
Weirdo23 is offline
Old 10-15-2008, 05:54 PM   #2
sdtundra
sdtundra's Avatar
Default Re: Where do you buy your parts? (oil, filters, etc.)
I have gotten things from Carson Toyota before when I had my Tundra, their prices are on the low side.
My local dealer has an Oil Change Pack for $14.99
5 qts oil, and filter
sdtundra is offline
Old 10-15-2008, 10:08 PM   #3
maseace
Prius enthusiast
maseace's Avatar
I get mine at Walmart.
Supertech filter: $3 (not poor quality like Fram, but has the same guts as the better filters).
5-qt jug of Mobil 1 0W-30 or 5W-30: $23.
Peace of mind that I did it right: Priceless.
New drain plug gasket not required, as long as it doesn't leak. Also a good idea to get a filter socket to make it easier to remove, since it's hard to get a good grip on it where it's located.
maseace is offline
Old 10-15-2008, 10:26 PM   #4
JimN
P719 of ???
JimN's Avatar
Thanks in advance!
I ordered a quantity of the cabin & engine air filters from them and split the order with another Prius owner to bring the shipping down to less than the sales tax.
JimN is offline
Old 10-16-2008, 03:30 PM   #5
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
Also note that you can buy a case of 10 Toyota-brand oil filters for $33 plus shipping, from Champion Toyota in Houston.
Champion ToyotaWorld
When buying parts on the web, it usually makes sense to place a bulk order (buy several engine air filters, cabin air filters, engine oil filters, and drain plug gaskets at one time) so that you can leverage the shipping charge across a larger number of parts. If you are only going to buy qty one of one part you will do better buying locally.
Patrick Wong is offline
Old 10-16-2008, 03:37 PM   #6
subarutoo
subarutoo's Avatar
Purolator oil filters and Fram cabin and air filters at Pep Boys. Oil (Mobil 1 5-30) at Costco or Walmart. You will need a small diameter filter wrench, less than $5 at Walmart. That's about it.
subarutoo is offline
Old 10-16-2008, 06:48 PM   #7
Weirdo23
Weirdo23's Avatar
Please keep your responses coming! This will surely be a useful thread for many in the future. Since I need to complete the oil change this weekend I ended up dropping by the local Toyota dealer last night. I paid $5.41 for the Toyota filter and $1.20 for the drain pan gasket. They also had the oil filter wrench for $5.99 which I picked up as well. In the future I'll likely place a bulk order. Now I just need jack stands
Weirdo
Weirdo23 is offline
Old 10-16-2008, 08:46 PM   #8
Ichabod
Artist In Residence
Ichabod's Avatar
Friends: 7
Get low profile ramps. It will make your oil changes faster and easier. Some people say they can do the change just fine without ramps or jacking up, but I like to take a look at the undercarriage while I'm down there. During my last oil change I noticed a broken axle seal, which I may not have seen if I didn't get the car up on ramps.
Ichabod is offline
buy, filter, oil, parts, source
My 2004-5 is damaged. Need used parts: airbags, RT Tail light, and all parts ahead of the engine prius4ed Gen II Prius Care, Maintenance and Troubleshooting 9 05-27-2008 11:05 PM
K&N Filters AF1PRIUS Gen II Prius Main Forum 3 05-15-2008 03:35 PM
Oil Filters ThePackage Gen II Prius Care, Maintenance and Troubleshooting 31 11-19-2006 10:46 PM
Filters andyprius Gen II Prius Care, Maintenance and Troubleshooting 4 07-19-2006 07:20 PM
K&N Air Filters green4evr2003 Gen II Prius Main Forum 6 03-07-2004 10:17 AM
