This is a discussion on Clicking problem in front-driver side wheel within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have an 04 Prius making a clicking sound that is coming from the driver's side, front window. It starts ...
Old 10-20-2008, 10:26 AM   #1
smithBYU85
smithBYU85's Avatar
Question Clicking problem in front-driver side wheel
I have an 04 Prius making a clicking sound that is coming from the driver's side, front window. It starts when I hit 7mph and is directly connected with speed (i.e. the faster I go, the louder and faster the clicking gets). I have checked the tire for rocks or foreign objects and it is free of objects. The sound is definitely metallic. It's about the same sound effect as putting a baseball card in the spokes of a bike tire, obviously it's not a cardboard sound but something metal. I haven't pulled the tire off to look for anything out of place, don't have the time right now.
Might it be the brake on the wheel? When I just roll forward I don't hear the sound, I have to hit 7mph before I do, so could it be the regen brake system? I don't know that much technical about the car, I understand most of how the car works, but not the nuts and bolts.
T. Smith
White 2004 Prius
smithBYU85 is offline
Old 10-20-2008, 10:48 AM   #2
galaxee
resident lab rat
galaxee's Avatar
Friends: 26
Default Re: Clicking problem in front-driver side wheel
does it get worse when you make turns? clicking in the drivetrain is generally a bad thing, and you'd want to get that checked out asap.
galaxee is offline
Old 10-20-2008, 11:52 AM   #3
drajkuma
Need More Input
drajkuma's Avatar
Two of my prior cars that made this clicking noise had to have their CV joints replaced. The 89 Ford Probe GT cost me 900. The 91 Honda Civic got traded.
Thanks
Dan
drajkuma is offline
Old 10-20-2008, 12:03 PM   #4
smithBYU85
smithBYU85's Avatar
No, the sound stays the same through turns. It stays the same while braking and in reverse, only changing as I change speed.
Thanks
Dan
Forgive, me what is a CV joint? It should be under warranty right (I have the Toyota extended warranty)?
Old 10-20-2008, 01:25 PM   #5
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
Prius has four constant velocity joints. Two are on each axle shaft leading from the transaxle to each front wheel. They allow the axle shaft to pivot as the wheels are turned from left to right, and as the suspension goes up and down.
Yes, if you have extended warranty coverage then that should cover the repair.
Patrick Wong is offline
Old 10-20-2008, 08:37 PM   #6
rigormortis
Package: #5 Touring
i think your supposed to look under the car and see if you see a lot of cv joint juice sprayed all over the place.
someone else had a clicking noise thread going recently, and it wasn't the cv joint, it was something silly, i forget
rigormortis is offline
Old 10-21-2008, 03:30 PM   #7
Gymshortz
To check if it's the CV joint put it in reverse and crank the wheel all the way... when moving in reverse this should accentuate the noise, I've usually described it as a creaking noise. It can be rather loud. If you get it early your boot may have cracked and the joint has lost the grease, it should be relatively cheap to replace the boot and regrease the joint ($200). I mean it beats the heck out of your wheel breaking off.
Gymshortz is offline
Old 10-21-2008, 04:54 PM   #8
Betelgeuse
Betelgeuse's Avatar
As rigor says, there was a thread recently where it was a loose wheel weight. However, a worn-out CV joint is a serious safety issue and should be addressed immediately. Clicking could be something minor, but it also could be something very dangerous.
Betelgeuse is offline
Old 10-21-2008, 06:06 PM   #9
rigormortis
Package: #5 Touring
yeah don't quote me and go driving on it. if you suspect that its the cv joint, stop driving it and have it towed. the wheel can fall off at any time with no warning and someone could die. on a more positive note, if you signed up for the platinum warranty back in 2004, this would be covered.
if you did not, then the joint would be covered for 60 months/60,000 miles. im estimating
that you had this for less then 60 months, and if your under 60k you should be covered.
so go tow it to the dealer asap
Old 10-21-2008, 07:22 PM   #10
smithBYU85
smithBYU85's Avatar
Funny thing, I went to try what was suggested, putting it in reverse and listening for the clicking, but I don't hear it at all right now. Strange, it has been constant. I'm going to jack her up tonight and take a look at the joints. I pray it isn't something serious, I can't be without my car right now and the closest dealer doesn't give out loaners, that I know of.
clicking, front-driver, problem, side, wheel
Smart Key Unlocking Question, Driver Side V.S. Passenger Side Grocked Gen II Prius Main Forum 26 04-17-2009 11:24 PM
Correction: Resolved "Clicking Noise From Front Wheel" IndyDoug Gen II Prius Care, Maintenance and Troubleshooting 1 10-10-2008 03:18 PM
Clicking sound from Driver's side door ooganya Gen II Prius Care, Maintenance and Troubleshooting 5 07-26-2007 04:02 PM
Clicking in driver door panel JohnTortorici Gen II Prius Main Forum 3 11-27-2006 02:42 PM
High frequency clicking by driver footwell bulldog Gen II Prius Care, Maintenance and Troubleshooting 3 07-27-2006 02:54 PM
