This is a discussion on Wheel bearing out? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Scraping noise when I slow down and turn left. Shop says it is a wheel bearing out, and even though ...
Wheel bearing out?
Old 11-05-2008, 11:48 AM   #1
gene4655
Default Wheel bearing out?
Scraping noise when I slow down and turn left. Shop says it is a wheel bearing out, and even though it's an '03 with 39,000 miles, it is under warranty. Anybody else have this problem? (And even before I found out it was under warranty, have to confess that the service technicians at McKinney Toyota in Ft Worth are the friendliest, most helpful I've found anywhere!)
gene4655 is offline
Old 11-05-2008, 12:01 PM   #2
jayman
Default Re: Wheel bearing out?
It has been known to happen early. Like most modern vehicles, the bearing is a sealed assembly and cannot be repacked. It must be replaced
jayman is offline
Old 11-05-2008, 12:55 PM   #3
VTMRGRTVL
VTMRGRTVL's Avatar
My '04 had the right front wheel bearing go at 45k miles. The dealer took care of it under warranty...
VTMRGRTVL is offline
Old 11-24-2008, 10:20 PM   #4
Guilt Edge
The left front wheel bearing also went on my 2005. 176 000 km (approx 110 000 miles). At first I thought it was an alignment problem, and so did the dealer.
Guilt Edge is offline
Old 11-25-2008, 01:04 AM   #5
Devil's Advocate
05 front left went out at 95,000. Helped along by a curb impact I think. The rest are still OK at 163,000. Replaced it myself for about $150 for the part from Hoy Toyota in TX about a year ago.
Devil's Advocate is offline
Old 11-25-2008, 03:07 AM   #6
tochatihu
tochatihu's Avatar
My Car: 2001 Prius
Package: Pioneer #1
Friends: 14
Prius fronts are cartridges that just need to be pressed in (slightly underestimating the work load there). For the rears, the whole wheel hanger assembly gets swapped.
We usta imagine that some of them got hurt on the boat ride over. If such did not occur, them expect them to last a very long time.
tochatihu is offline
Old 11-25-2008, 12:15 PM   #7
Priusaurus110
I've had same symptoms (and so have others in this forum) with a small pebble that got lodged in the brake rotor. Is the shop absolutely sure about the bad bearing? Did they remove wheel and brake and confirm you have no rocks caught against the rotor?
Just a thought...
Priusaurus110 is offline
bearing, out?, wheel
Front Wheel Bearing Russell Gen II Prius Technical Discussion 10 08-21-2009 10:42 PM
Wheel bearing needs replacing - how to avoid? mikepaul Gen II Prius Care, Maintenance and Troubleshooting 18 08-08-2008 08:29 AM
ABS/Brake light on after wheel bearing replacement btrotter Gen II Prius Care, Maintenance and Troubleshooting 10 04-10-2008 02:23 PM
Front wheel bearing jamesearthdrum Gen II Prius Care, Maintenance and Troubleshooting 2 03-12-2008 08:26 PM
$900 single rear wheel bearing 200Volts Gen II Prius Care, Maintenance and Troubleshooting 16 11-22-2006 02:00 PM
