This is a discussion on My Car would not go into drive. within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; If you have a digital voltmeter, measure the 12V battery voltage after the car has been IG-OFF for an hour ...
Old 12-28-2008, 09:59 AM   #11
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
Default Re: My Car would not go into drive.
If you have a digital voltmeter, measure the 12V battery voltage after the car has been IG-OFF for an hour or more. If the voltage is much below 12.6V then I suggest you replace the battery (or else try charging it if the car has been lightly driven.) If you charge the battery disconnect the negative cable terminal connector first, and use the low current setting (no more than 4A).
You'll probably need dealer help regarding the brake pedal switch. Or if you want to DIY, find the switch and measure resistance across the contacts when the pedal is very slightly depressed. If the switch doesn't immediately actuate upon a very slight pedal depression then the switch needs to be adjusted or replaced.
The switch has two sets of contacts, one for the cruise control system and the other to operate the brake lights and control when the transaxle can shift into a drive gear.
2006 Highlander Hybrid 4WD-i
2000 Ford Mustang GT conv.
Patrick Wong is offline
Old 01-06-2009, 09:28 AM   #12
milhouse
milhouse's Avatar
It happened again last night. Going to the dealer tomorrow. $90 just to look at it.
milhouse is offline
Old 01-06-2009, 09:50 AM   #13
Patrick Wong
DIY Enthusiast
Friends: 44
Originally Posted by milhouse View Post
... $90 just to look at it.
This is normal practice, the dealer wants to discourage you from coming up with random complaints. If you are willing to pay $90 then presumably you are serious regarding your issue.
If your problem is covered under warranty (i.e., 3 year/36K mile) then that labor charge should be waived.
Old 01-06-2009, 11:06 AM   #14
richard schumacher
Destination: Eschaton
You can also have the car do a self-test of the 12V battery with no tools needed. See the procedure given in jdedenberg's post in the thread here:
PriusOnline.com • View topic - how to put 12V battery in sleeping mode?
richard schumacher is offline
car, drive
my first drive! Elreq Gen II Prius Fuel Economy 5 04-24-2008 03:17 PM
Do you drive less? dragonfly Fred's House of Pancakes 10 10-27-2006 12:52 AM
Drive them if you have them 2Hybrids Prius and Hybrid News 34 04-03-2006 03:23 PM
You are what you drive jkash Fred's House of Pancakes 2 08-06-2004 01:30 PM
First Drive Gurmail Gen II Prius Main Forum 4 07-21-2004 11:47 PM
