This is a discussion on 2008 Prius Airbag light within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have read through numerous threads and on different forums but I just want to get a definitive answer. This ...
Old 12-08-2008, 10:48 PM   #1
laskint
Question 2008 Prius Airbag light
This all started because I went to get an annual vehicle inspection. My car failed because the inspector said that the airbag light was on. The manual states that when the car turns on the "Airbag On and Off" lights flash on then off after 4 seconds. It does this.
When my wife sits in the car, the "Airbag On" light comes on. When she gets out, the light "on" light turns off but the words "airbag" stay lit.
The manual states that there is a problem if the red driver side airbag light and the airbag off lights are lit. This is not the case. Just the "airbag" light.
Is this normal for a '08 Prius?
I am a little paranoid to take it to the dealer because I have performed the EV mod by adding a switch in one of the empty switch covers next to the dimmer. I did this after having the car for 1 week. I am afraid the dealer would tell me that this mod caused it which I am sure is not the case and tell me they cannot help me nor want to touch my vehicle.
2008 Classic Silver Metallic, Package #2
-EV-Mod
-Engine Block Heater
laskint is offline
Old 12-09-2008, 08:18 AM   #2
firepa63
Senior Citizen
Default Re: 2008 Prius Airbag light
It's normal. It's the same in my 09 and my brother-in-law's 06.
firepa63 is offline
Old 12-09-2008, 09:12 AM   #3
jelloslug
It buffed right out!
jelloslug's Avatar
The airbag waring light is red and near the speedometer. It will come on for 6 seconds when you start the car and then go off. The orange one on the passenger side is a status light for the passenger airbag.
jelloslug is offline
Old 12-09-2008, 09:29 AM   #4
Oddly enough, the passenger Airbag label stays lit. Only the on/off status light turns on and off.
Old 12-09-2008, 09:46 AM   #5
laskint
Thanks for the replies. I always remember seeing that airbag light and never thought twice about it. I spent 3 hours at the inspection station. I had the inspector call VA State Police who went through my manual and had the inspector pass my car. I just hate the fact that I might have to go through the same thing every year. I may just take it in to the dealer for the inspection every year and have them do some routine maintenance as well.
laskint is offline
Old 12-09-2008, 10:08 PM   #6
jelloslug
jelloslug's Avatar
You can move next door to me, there are no inspections at all in SC.
Old 10-21-2009, 05:28 PM   #7
Roakes_06_Prius
I just had the same issue having my 2006 inspected in MA. I spent 2 days trying to convince the inspector that the AIRBAG light on the passenger side is ALWAYS on and that if there was a malfunction the RED warning light located with all the other warning lights would be on... They almost had me go trough a formal complaint process to get it re-inspected... That process is 60+ days and results in a hearing of sorts to determine the outcome. In the end I got the service station that did the inspection to come to their senses...
Roakes_06_Prius is offline
Old 10-21-2009, 05:35 PM   #8
boppo
boppo's Avatar
Model: II
I thinks it's off until someone sits in the seat at least my 2006 is that way.
boppo is offline
Old 10-26-2009, 12:00 PM   #9
tom1l21
My red airbag light came on a couple months ago and won't shut off. I even got a new 12v battery as mine was getting low. That didn't fix the issue either. Where can I disconnect/reconenct the airbag connections? Would this possibly fix the issue?
tom1l21 is offline
Old 10-26-2009, 01:33 PM   #10
firepa63
Senior Citizen
Take the car to a dealer. The airbag is not a DIY item. You definitely have something wrong.
firepa63 is offline
2008, airbag, light, prius
Does the 2008 Prius have a glove box light Chuck41 Newbie Forum 5 06-18-2008 06:52 PM
Airbag light on the passenger side au071 Gen II Prius Main Forum 9 08-16-2007 08:36 PM
Passenger Airbag light krainium Gen II Prius Main Forum 10 05-07-2007 12:35 PM
Prius airbag safety terrykarp Gen II Prius Main Forum 2 12-29-2006 11:13 AM
Prius Airbag system mr5150 Gen II Prius Main Forum 16 08-10-2005 10:14 PM
