This is a discussion on Brakes Screeching issue within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hello, I am noticing that my brakes are screeching too much on my 2008. I only have 29k miles on ...
Old 01-20-2009, 11:16 AM   #1
Gilbert
Package: #5 Touring
Default Brakes Screeching issue
Hello,
I am noticing that my brakes are screeching too much on my 2008. I only have 29k miles on the care. Is it regular for this to happen so soon? i tought we didnt need brake replacements till past 100k or something. What do you guys recommend?
Gilbert is offline
Old 01-20-2009, 11:22 AM   #2
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
Default Re: Brakes Screeching issue
Maybe your front rotors are a bit rusty. You can try cleaning the brakes. Find a road with light traffic, get up to 45-50 mph. Then shift to N and moderately brake to a stop. Repeat a few times, see if that helps the noise issue.
Patrick Wong is offline
Old 01-20-2009, 11:54 AM   #3
KV55
KV55's Avatar
Package: T4
Is the screech when you apply them - suggesting the rotors - or at low speeds when they are not applied - suggesting a pad staying in contact when it shouldn't. My rotors were replaced at 30k under warranty and the pads at 50k, not under warranty.
KV55 is offline
Old 01-20-2009, 12:54 PM   #4
Gilbert
Package: #5 Touring
When applying brake.
Gilbert is offline
Old 01-20-2009, 01:18 PM   #5
richard schumacher
Destination: Eschaton
Or there's a stone stuck in one. Pads on a Prius should easily last 50,000 miles (unless you do lots of mountain driving and ride the brakes a lot).
richard schumacher is offline
Old 01-20-2009, 01:39 PM   #6
slickQUICKprius
I'm awesome!
slickQUICKprius's Avatar
Pads might just be worn down. At 29k I'd just take it to the dealer and ask to have the brakes looked at really quickly if it's still under warranty.
slickQUICKprius is offline
brakes, issue, screeching
OMG 2008 Prius screeching and grinding metal!!!! Twickle Purple Gen II Prius Main Forum 27 07-09-2009 06:00 PM
Screeching P-Brake and another question ystasino Gen II Prius Main Forum 2 10-30-2008 03:22 PM
I replaced my relatively new brakes w/new brakes saechaka Gen II Prius Care, Maintenance and Troubleshooting 1 04-17-2008 10:11 PM
sticky brakes psikot Gen II Prius Technical Discussion 3 12-30-2007 10:04 PM
Regenerative brakes versus friction (regular) brakes impreza Gen II Prius Main Forum 31 04-16-2004 09:18 AM
