This is a discussion on P0137 code and Check Engine Light within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I searched the forums and couldn't find any hits with this code so I thought I'd make a new one ...
Old 01-23-2009, 07:24 PM   #1
bnllovesme
bnllovesme's Avatar
Default P0137 code and Check Engine Light
I searched the forums and couldn't find any hits with this code so I thought I'd make a new one and ask for advice.
The check engine light came on yesterday morning but I wasn't having any problems with the car. I took it in this morning and when they ran the diagnostics it came up with the P0137 code. Since I was under warranty they replaced it quick and I was out the door in an hour. After some time on google it looks like it's an O2 Sensor? Does this mean my catalytic converter might go next?
Jackie
Steven Page of the Barenaked Ladies has seen the future and it ain't sweet, even though it involves sugar: "We'll need the last gallon of gasoline so we can go buy the last Krispy Kreme doughnut."
bnllovesme is offline
Old 01-24-2009, 09:21 AM   #2
Mike Dimmick
Package: T3
Default Re: P0137 code and Check Engine Light
This code's description is 'Oxygen Sensor Circuit Low Voltage (Bank 1 Sensor 2)'. This is the post-converter sensor, which confirms that the catalyst did its job. A low voltage indicates that the O2 sensor is reporting that there is a lot of oxygen in the exhaust. The computer thinks the voltage being reported is so low as to be a bad reading - that in fact it represents an open circuit (not connected).
Generally this code means that the sensor itself has failed, electrically. It doesn't have anything to do with the actual functioning of the catalytic converter.
If the code is repeatedly posted with a new sensor, it could indicate a hole in the catalyst letting in fresh air. Generally, though, the car would log P0420 (Catalyst System Efficiency Below Threshold) rather than this code.
Mike Dimmick is offline
check, code, engine, light, p0137
2005 Prius engine hesitation followed by check engine light politically corrupt Gen II Prius Care, Maintenance and Troubleshooting 3 01-14-2009 01:40 AM
Check Engine Scan Gauge Code P0456 priusFTW Gen II Prius Care, Maintenance and Troubleshooting 7 01-06-2009 01:22 AM
2005 - Check Engine Light with P1121 code newbie Gen II Prius Technical Discussion 3 05-28-2008 04:23 PM
Check Engine and P1455 Code davekall Gen II Prius Care, Maintenance and Troubleshooting 2 02-29-2008 10:08 PM
Check Engine Light jerollo Gen II Prius Care, Maintenance and Troubleshooting 8 03-19-2004 10:39 PM
