| This is a discussion on Water under the floor liner within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I put a windshield cover on the other day since we were going to get an ice storm. It rained ... |
#1 |
| Member Join Date: Apr 2007 Location: MA
My Car: 2007 Prius Model: Package: #9 Thanks: 0
Friends: 0 | I put a windshield cover on the other day since we were going to get an ice storm. It rained hard, and later froze, but no ice storm. I went out in the am, ice hanging down on the inside from the shield flaps, and water in the mats; and under the floor liner . I got under the liner on the passenger side and removed a pad, and cleaner what I could, used a hair dryer to dry it out. The driver's side, another story. I can not remove the gas door lever after I take out the bolt. I can not lift the liner to clean out under it. Any ideas how to do that? And, don't use those windshield protectors... Thanks. |
Friends: 0 | How can a windshield protector force water into the cabin? |
| Junior Member Join Date: Sep 2006
Friends: 0 | |
Friends: 0 | It appears that the water ran down the inside flaps; the door gaskets must not be that tight. |
Friends: 0 | That sounds horrible. I have an 07 also and live in Florida and it has seen some torrential rain also with no leaks. Never a leak.But of course no freeze. I'm a little confused on the window shield. Do you mean an outside shield that's covering the windshield in case of hail? I can't see how that's going to help water get inside. Only thing I can think of is maybe the rubber door gasket's were already frozen and did not make a seal. One poster here says that LPS Spray works good as a rubber gasket lubricant in the winter.Its basicly silicone spray.Helps in not allowing the gaskets to freeze. I do know I can sometimes hear wind noise from the front windows but still they have never leaked even the slightest even in some bad ass rains. Please post back with details. |
Friends: 12 | At one time, it was common for folks up here to put a tarp across the windshield, to keep frost/ice off it at -40. They learned quickly not to try that stunt near freezing temps, as the tarp would generously wick any rain directly into the car interior |
Friends: 0 | So, anyone with an idea how to remove the gas door release so I can get on the liner? Thanks. |
Friends: 44 | It sounds like the windshield cover is held in place by first opening the front doors, placing the cover down, then closing the doors to hold the cover in place. Apparently some water wicked through the cover material into the interior of the car, causing the flooding problem that the OP encountered. Unfortunately I don't have any suggestions about how to deal with the flooding on the driver's side, other than using towels to absorb water, then a hair dryer to dry the carpet. |
| Senior Member Join Date: Dec 2008 Location: Monterey
Friends: 1 | Quote:
If that is how it was secured, another possibility is that the material thickness just created enough of a gap to leak on top of that wicking action, no? | |
Friends: 0 | If you can park in a secure place leave the car Ready with the A/C set on outside (not recirculate), directed to the floor, and maximum temperature. Leave a window partly open. This will push a lot of hot air through the car quickly. (If in an enclosed garage, leave the door partly open. Fresh cool dry air must be able to enter near the garage floor and hot damp air and exhaust must be able to leave near the ceiling.) |
| floor, liner, water |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/57943-water-under-floor-liner.html | ||||
| MSN Shopping | This thread | Refback | 04-09-2009 03:45 PM | |
| Water keeps collecting on rear, passinger floor | cathcycler | Gen II Prius Technical Discussion | 23 | 07-24-2008 06:21 PM |
| one liner Puns | hycamguy07 | Fred's House of Pancakes | 61 | 07-10-2007 05:09 AM |
| Wheel plastic liner. | FishHawk | Gen II Prius Care, Maintenance and Troubleshooting | 1 | 03-05-2007 12:38 PM |
| Cargo liner/tray | BoosPrius | Gen II Prius Main Forum | 3 | 04-07-2006 02:37 AM |
| Anyone know a good cargo liner? | gas hater | Gen II Prius Main Forum | 8 | 01-19-2006 02:39 PM |
