This is a discussion on 2005 flasher unit within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I wish to add LED to signal lights but I was told it would mess up the flasher speed. Anyone ...
2005 flasher unit
Old 02-04-2009, 01:32 PM   #1
ogsimmons
ogsimmons's Avatar
Default 2005 flasher unit
I wish to add LED to signal lights but I was told it would mess up the flasher speed. Anyone know what flasher I would require to support LED signal lights?
ogsimmons is offline
Old 02-04-2009, 02:25 PM   #2
firepa63
Senior Citizen
Default Re: 2005 flasher unit
See my answer to your post on PriusOnLine...
firepa63 is offline
Old 02-05-2009, 04:03 PM   #3
maseace
Prius enthusiast
maseace's Avatar
If you're ok with it blinking 3x faster than normal, no flasher is needed. I don't think there is a load-independent flasher available that fits the Prius. You would probably have to go with load resistors. They are simply high wattage resistors that hook up near each turn signal bulb that trick the flasher into thinking that a regular bulb is there when the turn signal is on. The places that sell LED bulbs usually have load resistors for sale.
maseace is offline
Old 02-06-2009, 12:43 PM   #4
ogsimmons
ogsimmons's Avatar
Thanks for your help I will contact V-LEDs for the load resistors.
Dale
2005, flasher, unit
Replacing the head unit on '06 with double din aftermarket unit azzieo Gen II Prius Audio and Electronics 8 01-15-2009 10:37 AM
Aftermarket Head Unit for 2005 kcopen Gen II Prius Audio and Electronics 8 06-03-2008 04:02 PM
Just Finished the Flasher EV Mod treehggr Gen II Prius Modifications 0 06-08-2007 08:23 PM
EV mod with headlight flasher Renocat Gen II Prius Modifications 2 08-20-2006 07:25 PM
How to do the headlight flasher EV mod rerstad Gen II Prius Modifications 3 09-29-2004 10:16 AM
