This is a discussion on Prius leans left within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by yardman 49 Hello Fray: Could you elaborate on this question? Are you refering to my kitchen remodeling ...
Prius leans left
Old 04-14-2009, 11:18 PM   #11
Frayadjacent
Resident Conservative
Frayadjacent's Avatar
Default Re: Prius leans left
Originally Posted by yardman 49 View Post
Hello Fray:
Could you elaborate on this question? Are you refering to my kitchen remodeling project, or how the Prius handles??
Corner balancing is adjusting the suspension so that each wheel carries the correct portion of weight. Not sure if there really is a way to corner balance a Prius.
Frayadjacent is offline
Old 04-14-2009, 11:27 PM   #12
hobbit
hobbit's Avatar
Try getting a feel for how much force it takes to deflect a
corner of the car up or down a quarter or half inch. It's not
a whole lot of force, really. And it's got some stickiness
as a general rule.
The motors side of the engine/transaxle is significantly heavier
than the engine side. You also have more of the steering gear
on the left side of the car, and pedal assemblies, and probably
a few other things that realistically make the car left-heavy.
Then you pop in a driver, and yer definitely listin' to port.
When I load up my car I try to put heavier things over on the
right to balance against my weight and the existing offset, but
whether or not I accomplish that doesn't affect handling at all.
Really, I wouldn't worry about it. Try measuring some other
types of cars, they might be similar.
_H*
hobbit is offline
Old 04-14-2009, 11:57 PM   #13
yardman 49
yardman 49's Avatar
as a general rule.
_H*
Agreed. I'm not going to worry about it now. When I first really noticed it I was bothered, thinking that maybe it was a problem specific to my car. But then I started this thread, and KK immediately directed me to Toy08's thread. This forum really is such a huge help, especially to new owners.
After reading Toy08's thread, it was obvious to me that many Priuses had the same lean, so I decided not to worry about it. And what I discovered yesterday while at the dealership for an alignment further confirmed that fact (actually, even an '09 in the showroom had it).
It certainly doesn't seem to cause any handling issues with my Prius.
Frank
Seaside Pearl 2009 - package #5
yardman 49 is offline
Old 04-15-2009, 07:26 AM   #14
Mike Dimmick
Package: T3
Mine seems to lean to the left a bit too, and it's right-hand drive! I guess the iron cores on the motors' stator are pretty heavy, while the engine has an aluminium alloy block and head - and of course it's bored out as well.
I reckon the 2010 will be better balanced, given that the engine is larger - more weight on the right-hand side - and they've reduced both MG1 and MG2 sizes, and removed the silent chain over on the transaxle side.
Mike Dimmick is offline
Old 10-15-2009, 12:07 PM   #15
RadioMan
Mod Maniac
RadioMan's Avatar
My Car: 2010 Prius On Order
Model: II
This is extremely odd and not OK. My 2010 II leans 1.75" lower after taking out groceries etc.... and stays that way until I drive it un-loaded for a while. That's wacked. The car has almost no ground clearance to begin with. What - is there thermopedic foam in the suspension?
Does it affect driving? Don't know but will test it. Someone- somewhere- has an answer to this. Pre-load spring settings? Compensation for off-center weighting in the drive-train? Active load-balancing? Oatmeal-filled shocks?
What is happening here? I'm going to the dealer again today just to show them this is real.
Bob-Hot Springs
www.greenpowervideos.com
RadioMan is offline
Old 10-15-2009, 02:04 PM   #16
2009Prius
2009Prius's Avatar
Friends: 19
Question Re: Prius leans left
I saw a maybe related phenomenon on my 2009. I drove up and parked on ramps made of solid wood. I added jack stands as back up for extra safety. I inserted shims to fill the small space between the jack stands and the bottom of the car. Later I lifted the car a little, all tires were still on the ramps, then lowered the car back. Then all the shims became quite loose and stayed loose, as if the car had somehow floated higher up a few millimeters after being lifted and lowered back down. Maybe there is some large friction in the suspension.
2009Prius is offline
Old 10-15-2009, 05:06 PM   #17
yardman 49
yardman 49's Avatar
Bob-Hot Springs
Hello Bob:
Please let us know what the dealer says. I would have thought that by the G3, that Toyota would have had this corrected. That may have been an erroneous assumption on my part.
Best wishes,
Old 10-16-2009, 01:08 PM   #18
uart
uart's Avatar
Here in Australia our cars are also right hand drive (we also drive on the left side of the road) so I guess that slight imbalance is probably a good thing. I've never measured mine for a left lean, but I'm pretty sure that it isn't going lean left for very long after I plonk my 240 Lb fat arse in the drivers seat.
Ok on a serious note, I'm pretty sure they also drive on the left in Japan and so would also use right hand drive vehicles. Since the Prius was originally designed mostly with the Japanese market in mind perhaps that would explain the choice of weight distribution.
uart is offline
leans, left, prius
left prius on all night priusism Gen II Prius Main Forum 9 01-21-2008 07:26 PM
Prius Leans ghatid Gen II Prius Care, Maintenance and Troubleshooting 6 07-09-2007 05:45 AM
my Prius has left me for another man! betshsu Fred's House of Pancakes 6 03-18-2005 10:55 PM
My wife just left me and took the new Prius with her Robert Taylor Gen II Prius Main Forum 29 01-20-2005 05:20 PM
