This is a discussion on CHS Pump within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; (Apologies - I inadvertently posted this in the TSB section): OK, so I've perused the 100+ postings about bad coolant ...
CHS Pump
Old 05-02-2009, 01:46 AM   #1
jsorger
Default CHS Pump
OK, so I've perused the 100+ postings about bad coolant pumps and still have a question. I'm at about 130k and my pump sound has recently changed (temperatures haven't changed much - I'm in N. CA). No bearing sounds or grinding like in the much-appreciated .wav files. Simply went up an octave or so. I have plenty of fluid.
Anyone else? I assume it will fail soon, but I'm curious if anyone has experienced this (I'm way beyond warranty).
Thanks,
Jonathan
jsorger is offline
Old 05-02-2009, 01:34 PM   #2
dogfriend
Human - Animal Hybrid
dogfriend's Avatar
Friends: 11
Default Re: CHS Pump
I haven't seen any posts where the pump actually failed. Mine makes the noise but I haven't had it replaced yet (I am still in warranty until Feb 2012 - its covered under the powertrain 5 yr - 60k). I monitor the coolant temp using a Scangauge.
I would expect that if it actually fails to pump, you will get the Master Warning Light and it will set a code.
dogfriend is offline
Old 05-02-2009, 01:37 PM   #3
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
Since this pump only runs for a few seconds upon startup and shutdown, and your car is out of warranty, no point in worrying about the noise - unless you have a check engine light come on to show that a DTC was logged.
Even if the pump totally failed, this would not impact driveability. The only issue is that your car will emit slightly more HC during engine warmup.
Patrick Wong is offline
The Following User Says Thank You to Patrick Wong For This Useful Post:
jsorger (05-04-2009)
Old 05-04-2009, 02:11 AM   #4
jsorger
That's what I was thinking from reading the other posts... Thanks for the replies, as always!
jsorger is offline
chs, pump
ABS pump replace, does bleeding the brake lines get rid of air that might be in the abs pump? john1 Gen II Prius Care, Maintenance and Troubleshooting 5 10-08-2009 12:22 PM
Gas pump keeps shutting off patrickmaher Gen II Prius Care, Maintenance and Troubleshooting 15 01-29-2009 04:00 PM
Very odd experience at the pump BayAreaPrius1 Gen II Prius Main Forum 8 08-23-2008 12:55 AM
Pump up the mpg! perryma Newbie Forum 4 01-26-2008 10:12 PM
$3 and up at pump in '07? jkash Gen II Prius Main Forum 43 01-03-2007 11:59 PM
