Replaced 12v battery with Optima
| | #71 |
| Senior Member Join Date: Nov 2010 Location: Ireland/Eire
My Car: 2005 Prius Model: N/A Package: T4 Thanks: 30
Friends: 0 | |
| | #72 |
| Can I haz JDM? Join Date: Apr 2011 Location: Long Island, NY
My Car: 2006 Prius Model: N/A Package: #6 Thanks: 3
Friends: 2 | I used a trickle charger when replacing the OEM 12v with an Optima yellow top...worked perfectly...no settings lost no triangle of death, etc... |
| | #73 |
| Senior Member Join Date: Mar 2008 Location: Monroe, Ohio
My Car: 2008 Prius Model: Package: #5 Touring Thanks: 5
Friends: 1 | I do have a riding lawn mower battery. Would connecting jumper cables from that to the connection on the fuse box do the trick? |
| | #74 |
Friends: 59 | It would. Owners who use an auxiliary 12V source when replacing the 12V battery need to be very careful not to short the positive terminal to ground when removing the cables. |
| | #75 | |
| Junior Member Join Date: Oct 2011 Location: washington
My Car: 2005 Prius Model: Three Package: Navigation Thanks: 0
| Thanked by: | itsnicetobe (12-04-2011) |
| | #76 |
| Junior Member Join Date: Mar 2011 Location: Mid-Atlantic
My Car: 2008 Prius Model: Four Package: Navigation Thanks: 4
Friends: 1 | Just got my yellow top online direct from Optima. Couldn't be easier transaction. Does the car run better with the Optima? Could be.... |
| | #77 |
| A Wimpy DIYer Join Date: Mar 2009 Location: USA
My Car: 2009 Prius Model: N/A Package: #2 Thanks: 678
Friends: 22 | It would be nice to see some numbers from testing these Optima batteries. For example, turn the car IG-ON by pushing the power button twice without pressing on the brake. Turn the climate control fully off. Then turn the headlights on. What is the battery voltage? Then turn the rear defogger on. What is the battery voltage? |
| 12v, battery, optima, replaced |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/61243-replaced-12v-battery-optima.html | ||||
| Daox's 2004 Toyota Prius Build Thread - Page 12 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com | This thread | Refback | 08-25-2010 04:37 PM | |
| My 2001 Hybrid Battery needs to be replaced | titus37 | Gen II Prius Technical Discussion | 64 | 05-15-2012 09:33 PM |
| If you've replaced the main G1 traction battery, please tell us here! | Optimus | Generation 1 Prius Discussion | 41 | 06-26-2009 05:28 PM |
| Have you replaced your hybrid battery? | ghomner | Gen II Prius Main Forum | 37 | 06-15-2009 02:21 PM |
| Optima Battery Installation | mike3k | Gen II Prius Care, Maintenance and Troubleshooting | 14 | 04-21-2009 01:15 PM |
| Battery Cell #5 Replaced | jjf | Gen II Prius Main Forum | 13 | 12-21-2007 11:22 PM |
