Prius won't start!!!
| Junior Member Join Date: May 2009 Location: Albuquerque, NM
My Car: 2008 Prius Model: N/A Package: Base Thanks: 0
Friends: 0 | My wife & I have a new 08 Prius, bought in July, 08. Twice since we've owned it, first less than a month after purchase and just yesterday, the unit refused to start up. Just sat there in our garage. The first time, a couple of hours later, as we were getting ready to call the dealership, it turned over when we asked it to. We drove it into the dealership where they diagnosed it and adjusted some software directions. OK Yesterday, it died again. We called the dealership and they had it towed in. The technician called me this morning to report that it started up for them just before closing and that they were looking for the reasons why it failed. Their diagnostics showed no evident reason for failure, but twice in a year is out of line. Anyone have similar problems???? |
My Car: 2008 Prius Model: Package: #6 Touring Thanks: 586
Friends: 6 | TMahon0691, to PriusChat.If the car fails to do anything when you attempt to start it, the most likely scenario involves some failure involving the 12v battery. Since the car eventually starts, the battery itself may be OK. So, next in line comes the battery connections. Most likely problems here are loose connections at the battery itself. Then comes a possible loose or corroded battery grounding wire where it connects to the body, under the (removable) floor on the passenger side in the rear hatch area. Hope this helps. BTW, when you took the car in the first time, did the techs/service writer mention anything about retrieving any codes? |
| shortbus driver Join Date: Mar 2004 Location: United States
My Car: 2004 Prius Model: N/A Package: #6 Thanks: 582
Friends: 0 | Also have them check the brake pedal position sensors. You yourself might use the 12V battery system selftest procedure given here: Checking 12v Battery Health - Hybrid Car Forums Last edited by richard schumacher; 05-28-2009 at 10:47 AM. Reason: godd@mn POS server ate my first reply |
My Car: 2008 Prius Model: Package: T3 Thanks: 13
The OP doesn't say whether the car won't even switch on into ACC, or whether it just won't go READY. | |
| Thanked by: | richard schumacher (05-28-2009) |
| prius, start |
| Prius don't start | priusisthebest | Gen II Prius Technical Discussion | 25 | 11-27-2010 02:14 PM |
| Ran out of Gas, Now Prius won't start... | kraziewilly | Gen II Prius Care, Maintenance and Troubleshooting | 16 | 08-20-2010 07:16 PM |
| Cold weather related? Car won't start unless we try to start about 5-10 times | JasonInNJ | Gen II Prius Care, Maintenance and Troubleshooting | 20 | 01-25-2010 05:09 PM |
| '03 Prius won't start. | candlewick96 | Generation 1 Prius Discussion | 3 | 12-24-2008 12:28 AM |
| Help! Prius won't start without key | Dipena | Gen II Prius Care, Maintenance and Troubleshooting | 5 | 06-29-2008 04:37 PM |
to PriusChat.
