| This is a discussion on Master Warning, ABS, (!), and Hybrid Vehicle Warning icon within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Shawn, I have a very good handle on the computer firmware aspect of this discussion. From a microprocessor's point of ... |
| | #41 |
| Junior Member Join Date: Jun 2009 Location: Texas
My Car: 2005 Prius Model: N/A Package: #6 Thanks: 1
Friends: 0 | Shawn, I have a very good handle on the computer firmware aspect of this discussion. ![]() From a microprocessor's point of view, there is no difference between firmware, program code, and configuration data. The configuration data comprises BIOS settings that you refer to. The only real difference is that the BIOS and its default values normally reside in a static, or non-volatile, area whereas current BIOS configuration settings usually live in a separate volatile data area. (These areas are sometimes referred to as the “pure” and “impure” memory areas, respectively.) When the BIOS is reset to “default” the stored default/static values are written into the volatile area and are read as current configuration on the next boot-up. On many of today’s system boards with overclocking capabilities, it is very possible to come up with combinations of config settings that will not fly. Normally, a hard reset will force the next restart to clear the configuration area reload the defaults, but not always. There a number of possible reasons for this. (It is not useful to go into the details here.) Suffice to say that it is possible for the configuration area and even the non-volatile BIOS areas to become corrupted by an unexpectedly bad configuration or a crash. In such cases, it may be necessary to re-flash the BIOS to clean up the mess. Running the flash software will wipe the memory area clean, before writing a new BIOS image into it and restoring the default settings. This is why re-flashing the inverter firmware can be a good precaution to take. As a result, I have just passed the "SSC 50P" suggestion on to the service manager at the dealer repairing my car, hoping it will be part of the coolant pump repair job. -pdw |
| | #42 |
Friends: 0 | If you're talking about the hybrid ECU's flash, that's in the hybrid ECU and nowhere near the inverter. There's some custom iron in the inverter slave board but it's relatively simple. And probably designed to be quite heat-immune. . _H* |
| | #43 |
Friends: 12 | I wonder if any voltage spikes/surges could cause problems with the rewrittable portion of the ECM? |
| abs, hybrid, icon, master, vehicle, warning |
| Master Warning Light | Blinkn09 | Gen II Prius Main Forum | 15 | 05-27-2009 03:56 AM |
| Master Warning Light On | sockmonkey | Gen II Prius Care, Maintenance and Troubleshooting | 7 | 03-21-2009 11:17 AM |
| Master Warning Alert | jkark | Gen II Prius Care, Maintenance and Troubleshooting | 11 | 11-20-2008 09:38 PM |
| Master Warning Light | jarhtmd | Gen II Prius Care, Maintenance and Troubleshooting | 7 | 04-27-2007 09:11 AM |
| Please help with a Master Warning Light Problem | cpagal | Gen II Prius Care, Maintenance and Troubleshooting | 5 | 08-21-2006 02:58 AM |
