This is a discussion on 2010 prius oil change within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; We purchased our 2010 Prius III with Navi on 051709. I have over 2,300 miles on the car and plan ...
Old 05-30-2009, 10:34 AM   #1
alfon
Package: Navigation
Default 2010 prius oil change
We purchased our 2010 Prius III with Navi on 051709. I have over 2,300 miles on the car and plan on doing my oil change at 5,000 miles by myself.
I plan on using mobil 1 synthetic oil 0 W 20 weight.
I have heard that the new oil filter is now a removable cartridge and not the easy screw in type. This one has a paper element with O rings.
Also, is there a special tool required to take off the bottom engine cover so you can access the oil drain plug and the filter.
Any input would be a big help.
Also this Prius with the now bigger engine, 1.8 liter, holds, according to the owners manual, 4.4 quarts. This seems quite a lot of oil.
I plan on putting in 4 quarts and see where the oil level is on the stick. I like to have the oil level in the middle of low and max.
Thanks
Alfon
alfon is offline
Old 05-30-2009, 05:50 PM   #2
ETP
Ancient and decrepit
ETP's Avatar
Friends: 57
Default Re: 2010 prius oil change
Thanks
Alfon
My 240D had the cart and what a pain in the @@@. It also had a full flow bypass filter on top of the cart. Do they allow 0W20?
As to your question the book answer for class is the middle of the low and high mark. However, I fill it to the top just in case it sucks oil and I don't catch it. Most modern engines have a full pressure spray system and not cups on a crank shaft that throw oil on the bottom of the engine. Maybe? If you overfilled those old engines you could retard the cup action. OK guys be gentle on me. LOL Consequently the saying a little low on oil is ok.
I would not put any less than the middle of the fill marks and would strive to keep it full at every gas up.
ETP is offline
Old 05-31-2009, 12:42 AM   #3
FireEngineer
You need a small flat bladed screw-driver to start the prying of the under cover. In a pinch your fingernails will do (don't ask how I know ). Get a oil filter cap wrench that is 64mm with 14 flats. Don't use a 65mm, the cap is on pretty good from the factory and you don't want to round those edges. Don't remember the oil drain size, fairly standard.
Wayne
FireEngineer is online now
The Following User Says Thank You to FireEngineer For This Useful Post:
Azimuth (07-03-2009)
Old 08-04-2009, 04:13 PM   #4
bigcwill
Model: II
Thumbs down Re: 2010 prius oil change
I used a strap filter wrench. It needed folding to fit good. Worked fine off and on.
Pep Boys had Mobil 1 0W-20 for $29.99 5 quarts with a free Mobil One filter (that I got to fit the El Camino). The filter is worth $11. Toyota dealer had filters for $6.49.
So around $33 based on 4.4 quarts. I noticed fine metallic flakes in the oil visible in bright sunlight at 2,450 miles.
bigcwill is offline
Old 08-12-2009, 01:41 PM   #5
feslope
Does anyone know the part number of this filter? I would like to order a case from e-bay but want to be sure I get the right one.
feslope is offline
Old 08-31-2009, 03:20 PM   #6
Kepner
Model: V
Package: Adv. Technology
Smile Re: 2010 prius oil change
Thanks
Alfon
I have used an office staple puller to remove the plastic buttons from the bottom engine cover.
Kepner is offline
Old 08-31-2009, 04:32 PM   #7
TKY
Toyota part number - 04152-YZZA6. Purchased from a Toyota dealership, it included a new o-ring.
Don't forget to replace the washer on the oil pan drain plug. --TK
TKY is offline
The Following 2 Users Say Thank You to TKY For This Useful Post:
feslope (08-31-2009), KD4MNI (09-14-2009)
Old 08-31-2009, 04:54 PM   #8
feslope
Thanks for the info. I really coulden't find that anywhere.
feslope is offline
Old 08-31-2009, 06:25 PM   #9
MattsGen3
Model: II
I will be due for an oil change soon.
In my previous cars I have always used WIX filters. I believe it is one of the higher quality filters in the market. Their part number for 2010 prius is 57064 comes with gaskets.
I buy the filters here for $3.04 + shipment It comes in a case with 12 filters.
anybody else tried/used wix filters ?
MattsGen3 is offline
The Following User Says Thank You to MattsGen3 For This Useful Post:
feslope (09-23-2009)
2010, change, oil, prius
(MT) Video: Comparison: 2010 Honda Insight vs 2010 Toyota Prius Tideland Prius Prius and Hybrid News 8 07-08-2009 04:11 PM
2010 Toyota Prius vs. 2010 Honda Insight Comparison: Battle of the Fuel Sippers—The Rematch Tideland Prius Prius and Hybrid News 23 04-30-2009 12:43 AM
Feature: 2010 Honda Insight vs 2010 Toyota Prius Tideland Prius Prius and Hybrid News 13 01-28-2009 01:37 PM
2010 Toyota Prius vs. 2010 Honda Hybrid KayakerNC Gen II Prius Main Forum 5 08-19-2008 10:47 PM
2010 Lexus Hybrid Drawing (2010 Prius?) Tideland Prius Prius and Hybrid News 8 04-14-2008 07:32 PM
