| This is a discussion on Poor Idle is driving me crazy! within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by Patrick Wong This is almost like asking how to make a car run without a functioning transmission. ... |
| | #31 |
My Car: 2007 Prius Model: Package: #6 Thanks: 790
Friends: 11 | |
| | #32 |
My Car: 2004 Prius Model: Package: B Thanks: 82
Friends: 14 | Just keep flooring it. The transmission will eventually "catch" and go into gear. Or, you'll grenade the transmission. Either way, problem solved |
| | #33 | ||
Friends: 11 | Quote:
98 Auto Transmission PROBLEM! HELP! - Ford Explorer Ranger Enthusiasts Serious Explorations Quote: My reply: Quote:
| | #34 |
My Car: 2007 Prius Model: N/A Package: #4 Thanks: 53
Friends: 45 | Hey Jason, I sold my 1997 Ford Explorer XLT 5.0L V8 AWD w/4 speed automatic overdrive at 95K miles, in mid-2005 after I bought the HiHy. The transmission had been solid up to that point, absolutely no issues. Do you find that drivetrain combination has lots of reported problems? |
| | #35 | |
No, the V8 is paired with the 4R70W which is a much stronger transmission. Those seem to be relatively bulletproof. The 4.0L V6 got the bad transmission(s). The 1st gen Ex (91-94) had the A4LD (which was based on the C3, a Pinto trans). Those transmissions fail regularly. The 2nd gen (95-96) got the 4R55E which is an electronically controlled A4LD. They were upgraded to be a little stronger, but are failing rapidly now. From 97 - 01, they used the 5R55E, which has another gear between 1st and 2nd, making it a 5 speed plus some other upgrades to make it a little stronger. I have 119k on mine, but I see that a lot of them fail before that. The 3rd gen (02+ ) with IRS uses the 5R55W which is sealed without a dipstick. Apparently Ford believed that they had improved the design enough that regular checking of the fluid level and condition was not necessary. Apparently they were wrong, because I am seeing more posts on failed 3rd gen transmissions as time goes on. | |
| | #36 |
Friends: 14 | Reminds me of the debacle GM had when they went to the 700-R4 (Remarkably weak and unreliable), or Ford with their first AOD in the LTD (Hit the brakes hard on the highway, brakes lock up, overdrive won't disengage, motor stalls, power steering quits, crash, etc), or how about those flimsy transaxles in early to mid 1990's Dodge minivans. The car makers have known how to build solid and reliable automatic transmisions for over 40 years. GM had the TH350 and the stump-pulling TH400, Ford had the C6, and the Ford C5 was ok, Chrysler had the 727. These were fairly simple transmissions, as far as automatics go, and with somewhat routine servicing would last a long, long time
__________________ 2007 Toyota FJ Cruiser 5AT "C", Sun Fusion |
| | #37 |
Friends: 11 | I ran across another sad story this morning: Newbie Needin Some Guidance - Ford Explorer Ranger Enthusiasts Serious Explorations It is actually kind of amazing: Ford can build decent transmissions as evidenced by some of the other models, but for the Explorer, they can't seem to extract their cranium from their poop hole. I guess that the transmissions usually make it through the warranty period, and that is all that matters to management. My understanding is that Ford will soon stop production of the truck based Explorer and replace it with a crossover type SUV. |
| | #38 |
Friends: 14 | "Cranium in poophole" That would be a good Truth In Advertising jingle |
| | #39 |
Friends: 11 | I can't think of anything to rhyme it with. Maybe Stev0 can work it into a jingle. |
| | #40 |
| Senior Member Join Date: Mar 2009 Location: new york
My Car: 2006 Prius Model: Package: #2 Thanks: 5
Friends: 3 | Sorry about the 5v part. I did mention it in another post a few months ago. I thought about the 5 v balance, but I tried a lab supply, and varied the voltage, no help. I will try disconnecting the MAF, didn't know about the default map. Based on the tests I ran, I am leaning towards a vacuum leak. I brought it to a shop with a smoke machine. At first they were enthusastic about working on the car, they liked the challenge. Then they came to me with a list of things that were wrong. I had to go through them point by point in the Toytoya manual, and explain why they were not wrong. After that, they todl me they wouldn't work on the car. They wouldn't even do the smoke test for the vacuum leak, which is all I asked them to do to begin with. |
| crazy, driving, idle, poor |
| Can't get back over 50 MPG - driving me crazy | saminjax | Gen II Prius Main Forum | 17 | 04-18-2008 01:43 PM |
| Seat Belt Holder Thingie Driving Me Crazy | pvpost | Gen II Prius Main Forum | 3 | 07-20-2007 03:53 PM |
| Poor, poor, Maggie... | Mystery Squid | Fred's House of Pancakes | 3 | 05-17-2006 06:29 PM |
| Poor, poor Oil Companies. | Godiva | Prius and Hybrid News | 61 | 02-01-2006 11:31 AM |
| Waterdrops are driving me crazy!!! | V8Cobrakid | Gen II Prius Care, Maintenance and Troubleshooting | 21 | 09-06-2004 06:19 PM |
