This is a discussion on Going to try the Clay Kit for the first time within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I'm going to do it by the book first time through - Gold Class car wash Dry Lots of lube ...
Old 06-17-2009, 12:37 PM   #11
cycledrum
hybrid car with a hybrid seat
cycledrum's Avatar
Default Re: Gong to try Clay Kit for first time
Gold Class car wash
Dry
Lots of lube and clay small sections
NXT 2.0 Tech Wax
Will take well into the afternoon even starting at 7am. Takes me until noon to finish wash/dry/wax.
liverbomb88 - that's an intense routine!
cycledrum is offline
Old 06-17-2009, 09:27 PM   #12
liverbomb88
Push the Button!
liverbomb88's Avatar
Actually, it's just what you are going to do with an extra wash snuck in -- my description is just a bit detailed and wordy.
BTW, you can extend the life of your NXT 2.0 (synthetic sealant) with Megs Ultimate Quick Wax (UQW). Just spray on and wipe off UQW after your car washes.
liverbomb88 is offline
Old 06-17-2009, 09:33 PM   #13
Jabber
Chicagoland Prius Guy
Friends: 13
I have been claying for years. Liverbomb88, you have the best routine I have ever seen. For anyone wanting to claybar for the first time, follow his advice to a tee.
Jabber is offline
Old 06-17-2009, 09:59 PM   #14
liverbomb88
Push the Button!
I just finished detailing a white Civic today and wanted to share a picture with all of you. I washed the car very thoroughly with Dawn. The paint was squeaky clean but felt rough. I then clayed it, and you can see how much grime was still left in the paint after wash (the clay is supposed to be white):
Old 06-18-2009, 11:41 AM   #15
cycledrum
cycledrum's Avatar
I could see keeping a bucket of soapy water (with Dawn) and a cloth to wipe lube on in addition to spraying QD.
Old 06-18-2009, 12:50 PM   #16
TonyPSchaefer
Your Friendly Moderator
TonyPSchaefer's Avatar
Friends: 27
All this talk about claybar is making me think that for Priapus' 5th birthday I should get him a thorough claybar cleaning.
TonyPSchaefer is offline
Old 06-19-2009, 01:28 AM   #17
Tideland Prius
Moderator of the North
Tideland Prius's Avatar
Friends: 26
Damn right. It's about time!
soapy water works as a substitude for QD solution. Don't think it has to be with dawn.
Tideland Prius is offline
Old 06-24-2009, 02:31 AM   #18
cycledrum
cycledrum's Avatar
I clayed a much neglected family member's 1992 car, just the roof. Took about an hour just to do the roof. Kept going over a section until no more 'brown stuff' showed up on clay. Did lots of kneading after dirtying both sides.
Claying sure does make a finish turn from rough to smooth. In this case, they would need someone else to polish the paint. I'm not going to get into that.
My Prius will need claying before the next wax. I'll do a portion of the roof to make sure I'm not scratching anything.
09 Spectra Blue Mica Package #5 : Mods - Height adjustable driver's seat created from blending 06 Prius seat with 06 Corolla frame and trim, seat remounted 2 5/8" back with custom 'rail extender' braces and welding, reshaped seat bottom foam, sheepskin seat bottom cover, velour seatback cover, 7/8" foam added in headrest covers.
Old 06-24-2009, 07:59 AM   #19
F8L
Collecting Data on Nature
F8L's Avatar
Friends: 36
My routine is basically the same as Liverbomb's. The claying part goes pretty quick for me. It's the multiple applications of Zaino that takes the longest for me.
I don't use spray detailers when I clay though. To save money I simply put car wash into a spray bottle (with water) and use that to keep the paint wet and lubed up. It's worked fine for years and saves my Quick Detailer for well, quick detailing.
F8L is offline
Old 06-24-2009, 08:03 AM   #20
F8L
F8L's Avatar
Friends: 36
A spray bottle with soapy water is a much beter idea and you are less likely to pick up contaminants that could fall into the bucket then you go litterly scubbing them into your paint.
F8L is offline
clay, gong, kit, time
Anyone have 800 Lbs of clay handy? New mythbusters episode Jabber Gen III 2010 Prius Fuel Economy 74 11-11-2009 03:54 PM
Date and time change not synced outside of Eastern Time? aforkosh PriusChat Website Questions 7 11-04-2009 12:58 PM
MFD damaged by clay.... tony g Prius and Hybrid News 42 05-09-2009 11:49 PM
would like feedback on Turtle Wax ICE liquid clay and synth polish cycledrum Gen II Prius Care, Maintenance and Troubleshooting 3 02-08-2009 10:11 PM
I need clay help! bigbaldcuban Environmental Discussion 1 04-24-2004 06:27 PM
