This is a discussion on leaking Radiator (or hose). Please help within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by jayman I agree. I personally will use the genuine Toyota SLLC. Prestone advertises a "universal" long life ...
Old 07-30-2009, 01:06 AM   #21
nthach
Default Re: leaking Radiator (or hose). Please help
I agree. I personally will use the genuine Toyota SLLC. Prestone advertises a "universal" long life coolant that may be compatible. I personally do not think the potential "savings" are worth having major problems
Prestone All Makes/All Models=Dex-Cool in drag, it has the same chemicals in it. Peak Global Lifetime has no 2-ethylhexanoic acid or sodium/potassium neodecanate - or so what Old World Industries says. There's rumors that Peak Global Extended Life at Wal-Mart isn't the same as the Lifetime.
nthach is offline
Old 07-30-2009, 09:18 AM   #22
hobbit
hobbit's Avatar
Not to hijack the thread, but recently I drained small samples
of engine coolant from all three drain points and observed that
the stuff is as bright pink as the day it went in. At over 100K
miles. What does that say about the chemistry, if anything?
Vaguely related, where can one get *small* quantities of those
test strips for coolant and brake fluid?
_H*
hobbit is online now
Old 07-30-2009, 02:44 PM   #23
jayman
Tells me that Toyota knows what they are doing. Remember back when motors had the green stuff? If you went 2-3 years, the rad was a scaled-up mess
Regarding the test strips, I've never seen them sold for individual use. I suppose you've tried all the usual suspects? Eg Autozone, PepBoys, NAPA, etc
This is a typical quantity of test strips
Run-Rite.com : PRODUCTS: Fluid Rx Multi-Fluid Test Kits
Just the ticket if you decide to start reparing Prius cars on a huge scale!
jayman is offline
hose, leaking, radiator
Rusted hose clams FishHawk Gen II Prius Care, Maintenance and Troubleshooting 9 11-11-2008 11:01 PM
Ford recalls 180,000 SUVs, vans to fix door and fuel hose problems cwerdna Other Cars 2 03-06-2008 12:59 AM
3 Struts leaking? Jsiegel Gen II Prius Main Forum 12 02-13-2008 12:43 AM
Leaking with Coastal XM Kit? exces6 Gen II Prius Audio and Electronics 7 09-08-2007 05:57 PM
Leaking windshield Bill Lumbergh Gen II Prius Main Forum 4 02-06-2006 12:03 PM
