| This is a discussion on 2008 Easy Oil Change within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Bought our Prius used at 9000 miles and just did my first oil change. I have done oil changes on ... |
| Junior Member Join Date: Mar 2009 Location: Findlay, Ohio
My Car: 2008 Prius Model: N/A Package: #2 Thanks: 0
Friends: 0 | Bought our Prius used at 9000 miles and just did my first oil change. I have done oil changes on all of my vehicles since I started to drive in the 70's. The only thing new to me was I was doing it on a Toyota and not a Dodge, GMC, or Oldsmobile. Latex gloves and a oil cleanup rag and I didn't even get dirty. That was the easiest oil changes I ever did, and it was the cleanest 5000 mile oil I ever disposed of. The nice oil change tutorial and suggestions of the proper ramps helped make it like I have done it a hundred times before. Got a fantastic deal on 5 quarts of Penzoil Platinum Full Synth 5W-30 and a Mobile 1 filter. Still have 1.5 Quarts left to use the next time. Thanks Bob |
| Senior Member Join Date: Jan 2009 Location: Boston, MA
My Car: 2009 Prius Model: Package: #2 Thanks: 22
Friends: 1 | I know. I love the positioning of the filter and the drain plug. Amazing how clean and easy it is to do an oil change on the Prius. I didn't think I can love the car anymore until I did that and I thought to myself, "wow, that's just brilliant." |
My Car: 2007 Prius Model: Package: #7 Thanks: 9
Friends: 0 | If you use a vacuum pump to suck the oil out,, you get more out, and it is REALY easy. Small hand pumped vacuum cost ~$50 from the marine store. The first time I used one,, it left less than 2 drops in the pan when I pulled the plug to check. I don't ever pull the plug,, thereby no risk of overtightening or cross threading it. Icarus |
| 2008, change, easy, oil |
| Tires-Easy not easy to deal with/Kudos to MK Discount Tire | Joe 26 | Gen II Prius Care, Maintenance and Troubleshooting | 0 | 11-21-2008 10:08 AM |
| 2 easy rules for better MPG | chrisspaulding | Gen II Prius Fuel Economy | 16 | 07-07-2008 09:39 AM |
| It's Not Easy Being Green... | tedmarshall | Gen II Prius Main Forum | 5 | 10-23-2007 01:37 PM |
| Easy Tar removal | justin96039 | Gen II Prius Care, Maintenance and Troubleshooting | 12 | 07-27-2006 09:59 AM |
| If You Think Cops Have it Easy | DaveinOlyWA | Gen II Prius Main Forum | 1 | 11-14-2004 07:45 PM |
