| This is a discussion on Make your Prius last approximately forever : Part 1 within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; This advice applies to any auto, not just Priuses. When your engine runs hard for a while (1/2 hr or ... |
| I also have a 2007 Prius Join Date: Nov 2007 Location: 200 mi N of SF Bay area
My Car: 2008 Prius Model: Package: #4 Thanks: 0
Friends: 0 | This advice applies to any auto, not just Priuses. When your engine runs hard for a while (1/2 hr or more), it accumulates a heat load. As long as you keep it running, this load is continuously removed by the cooling system (coolant plus radiator (heat exchanger)) and dumped into the surrounding air. When you stop, the heat removal stops. Some earlier auto models had an electric radiator fan that ran whether or not the ignition was on, but this runs down the 12V battery and is a safety hazard for anyone working under the hood. Now the car is sitting there with a large lump of hot metal under the hood. The hood is insulated and there are no vents or louvers in the hood of a modern car. What happens? Everything under the hood comes to a temperature much higher that ambient, much higher than it ever reaches when the car is running. There is a mess of plastic and rubber components under the hood. Although I'm sure Toyota uses the very best they can afford, these components do chemically decay; the rate of decay is an exponential function of the temperature and a linear function of time. Those of us who drive our cars for 15 years have experienced a rubber valve cover gasket which turns into hard, brittle plastic. Similar things happen to all rubber and plastic components. Thus: the less the non-metal underhood components are exposed to high temperature, the longer they will last. When you get off the road on a hot day after hard running, open the hood for an hour. If you get a new car every 2 years, you will never know the difference. But if you run your Prius for the 10+ years that they are (over) engineered to run, you will. |
| Senior Member Join Date: Dec 2006 Location: Pennsylvania USA
Friends: 0 | Possible, but questionable. |
Friends: 33 | I call BS My last Toyota was 16 years old when I sold it. I currently own a Toyota Crown, built in 1968, with all original hoses etc. |
Friends: 26 | you're going to have to replace gaskets and seals after time and use anyway. |
My Car: 2007 Prius Model: Package: #6 Thanks: 282
Friends: 11 | I'm more concerned about keeping those IGBTs in the inverter cool than the hoses and gaskets, but that's just me. |
| The Following User Says Thank You to dogfriend For This Useful Post: | SageBrush (07-21-2009) |
| Rare Under-30 Priuschat Member Join Date: Jun 2008 Location: Chicago, IL
My Car: 2008 Prius Model: N/A Package: #3 Touring Thanks: 9
Friends: 9 | So you're telling me I need a turbo timer for my prius too? |
Friends: 8 | |
| Dittohead Join Date: Jun 2009 Location: Ohio
My Car: 2006 Prius Model: N/A Package: #8 Thanks: 0
Grill blocking? Do you mean purposely obstructing the air flow to your radiator? | |
My Car: 2010 Prius Model: N/A Package: Technology Package (Canada) Thanks: 229
Friends: 23 | Correct. The engine shuts off, remember so during the winter time, we block the grill to help keep the heat in. (Don't forget that in the winter, you're extracting heat from the engine to heat up the cabin anyway so I don't think the issue with heat pooling is as great). So don't worry, we don't block it in the summer. |
| approximately, forever, make, part, prius |
| -15F outdoor air temp = turtles forever | ChapmanF | Generation 1 Prius Discussion | 2 | 01-15-2009 10:31 PM |
| Is Hell Forever? | Wildkow | Fred's House of Pancakes | 301 | 03-15-2007 03:56 PM |
| If you're not part of the solution, then you're a part of the problem! | Mirza | Environmental Discussion | 29 | 02-20-2007 01:02 AM |
| Remaining number of HOV Stickers as of 9/22 approximately 2000 | NicNicholson | Prius and Hybrid News | 4 | 10-04-2006 06:27 PM |
| The easy part is over now the hard part | skew | Order Tracking | 4 | 09-19-2004 10:29 PM |
