| This is a discussion on Check engine light on Valve to the coolant pump failed. Is it right? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I had my 04 Prius with 71900 mile for one day and the check engine light was on, and the ... |
| Junior Member Join Date: Jul 2009 Location: New Jersey
My Car: 2004 Prius Model: N/A Package: N/A Thanks: 0
Friends: 0 | I had my 04 Prius with 71900 mile for one day and the check engine light was on, and the MFD was not workign right (had the well known communication problem with Air conditioning and radio and slow response). I took back to the dealer (unfortunately a Honda dealer but new car dealer nonetheless). They agreed to fix the problems and it has been their for 5 days. Yesterday they told me the chek-engine-light problem was due to the failure of the valve to the the coollant pump. I don't know what the valve means. They also told me the pump was working fine. Is there a potential problem with the statement? They told me that they replace the valve with a part ordered from Toyota and that was why it took so long, and the check engine light is off now. They did everything with their own computer with using the MFD and I think they kind of forgot the MFD failed as well. They are working on the MFD now. |
| Senior Member Join Date: Mar 2009 Location: USA
My Car: 2009 Prius Model: Package: #2 Thanks: 246
Friends: 19 | Sounds similar to this: Engine light = bad hybrid system coolant valve: Warranty? Help! You can ask the dealer for the DTC codes and do some research. |
| | #3 | ||
My Car: 2004 Prius Model: Package: Base Thanks: 0
Friends: 10 | Quote:
JeffD | ||
| Junior Member Join Date: Jul 2009 Location: California
My Car: 2004 Prius Model: II Package: Navigation Thanks: 0
Friends: 0 | Crap. Now I just got the p1121 error code. I was able to find the technical service bulletin but can't seem to post an external link because I'm newbie here. I found it pretty fast, so you should be able to do so as well by searching terms 'prius p1121'. The steps to install sound fairly easy to do, but was wondering if anyone has done this. I found the below thread which mentions the part costing around $70, but the link to that web site is bad. ..forums/gen-ii-prius-technical-discussion/39624-coolant-flow-control-valve-air-heating-issue.html In any case, if anyone has installed this themselves, please give me a holler. If I can figure it out and do it myself, I will definitely post pictures of each step for everyone else. Thanks. |
Friends: 0 | Odd... on obd-codes.com, it lists this for toyota code: P1121 Accelerator Pedal Position Sensor Range/Performance Problem. |
Friends: 44 | Generic interpretations of Prius DTC often are incorrect. DTC P1121 is "Coolant Flow Control Valve Position Sensor Circuit Stuck". There are three possible reasons for this DTC. Either the valve is bad, or the cooling system is clogged, or the engine ECU has failed. |
| check, coolant, engine, failed, light, pump, valve |
| Engine light = bad hybrid system coolant valve: Warranty? Help! | mstucky | Gen II Prius Main Forum | 11 | 08-25-2009 10:06 AM |
| Prolonged high pitch sound (engine coolant thermo pump?) at startup | 2009Prius | Gen II Prius Care, Maintenance and Troubleshooting | 1 | 07-01-2009 06:59 AM |
| Video of new engine coolant pump for Gen3 | Jay C | Gen III 2010 Prius Technical Discussion | 2 | 06-24-2009 04:34 AM |
| 07 prius check engine light. need to bleed the air in the coolant? | cdsjklee | Gen II Prius Technical Discussion | 13 | 09-24-2008 04:42 PM |
| Coolant pump check | bredekamp | Gen II Prius Technical Discussion | 10 | 05-17-2008 02:27 PM |
