This is a discussion on 2006 w/ nav MFD touchscreen stopped responding within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have run into my first scary issue with my beloved '06 Prius purchased new in March 2006 . The ...
Old 08-01-2009, 02:53 PM   #1
Trevor
Default 2006 w/ nav MFD touchscreen stopped responding
I have run into my first scary issue with my beloved '06 Prius purchased new in March 2006 . The car hasn't seen the dealers service department in over a year thanks to the courage that this site has given me to do my own maintenance and I'm just hoping to keep it that way for a little while longer.
The display is still fine, but the touchscreen won't respond. It happened suddenly. I was at a red light so I decided to start to program the nav for an upcoming business trip but it did not respond. I couldn't hit the accept button on the nav disclaimer. The next time I came to a stop I tried a few other screens and at one point it seemed like the screen needed to be calibrated because I touched one button but a different one above it on the screen registered. I took a deep breath and hoped that somehow it would start working again the next time I used the car. I have not gotten it to respond since.
Is there any way possible that this could be a 12V battery issue? (grasping at straws). I can do most of what I need to do with the steering wheel controls, so my main need for the screen is the GPS. I figure that I can get a portable GPS for cheaper than getting the problem diagnosed.
Most of the MFD's that I have seen on ebay are for cars without the nav and some have been listed as supporting '06 models produced through 10/05. Will I have to take the dash apart to find the exact replacement part number or will I have to purchase the service manuals to get that info.
2006 Seaside Pearl #7
Acquired 3/9/2006
Trevor is offline
Old 08-01-2009, 02:55 PM   #2
Default Re: 2006 w/ nav MFD touchscreen stopped responding
I assume you have power cycled the MFD and still have a problem. Have you tried cleaning the screen with an LCD safe cleaner? Sometimes oil and dirt buildup can cause erratic touch screen operation.
Old 08-01-2009, 03:15 PM   #3
Trevor
The car has been powered off and on many times (issue started 4 days ago), but not specifically the MFD. Thinking about disconnecting the 12V battery to see if that resets anything.
The screen is clean. It only had erratic behavior for a brief moment and then no response at all after that.
Trevor is offline
Old 08-02-2009, 07:47 PM   #4
JimN
P719 of ???
JimN's Avatar
Trevor, do the buttons work on any screen? If you are disconnecting the 12V test the voltage.
JimN is offline
Old 08-02-2009, 11:05 PM   #5
Trevor
The touchscreen does not work on any screen. It worked flawlessly until the day it stopped working. Unfortunately I have a business trip this week, so I did not have an opportunity to attempt to disconnect the battery or test it.
Trevor is offline
Old 08-17-2009, 01:58 AM   #6
uclabruins
uclabruins's Avatar
Package: #8
Sorry to hear your troubles. This is my biggest fear for my 2006. I didn't purchase an extended warranty, so I'm hoping that my MFD doesn't fail.
uclabruins is offline
2006, mfd, nav, responding, stopped, touchscreen, w or
2006 - Blower stopped working, for a while... ttabbal Gen II Prius Care, Maintenance and Troubleshooting 2 06-30-2009 06:35 PM
Touchscreen says AC disconnected and side panels not responding solster Gen II Prius Care, Maintenance and Troubleshooting 8 09-23-2008 07:22 PM
Gas Pedal Stopped Responding priusnowork Gen II Prius Technical Discussion 21 07-01-2008 08:10 AM
Responding to silliness ice weasel Gen II Prius Main Forum 6 10-12-2006 08:07 PM
Coastaltech not responding? barryhund Gen II Prius Main Forum 14 08-10-2005 09:58 AM
