| This is a discussion on JiffyLube told me this about my MAINT REQUIRED light... within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; No offense, but what are you nuts? Haven't you ever seen all those awful horror stories about Jiffy Lube in ... |
| | #31 |
| Junior Member Join Date: Aug 2009 Location: WA
My Car: 2007 Prius Model: N/A Package: Technology Package - CA Thanks: 0
Friends: 0 | No offense, but what are you nuts? Haven't you ever seen all those awful horror stories about Jiffy Lube in the media? Damn, I wouldn't trust one of those quickie lube places to change the oil on my old 94 Dodge Pick/Up, let alone my high-tech hybrid vehicle! Those quick lube places will hire anybody and they're filled with ex-cons and high school dropouts. Some of these guys will damage your car on purpose just so they can charge you to fix it! |
| | #32 |
| Senior Member Join Date: Jul 2004 Location: Belle Harbor, NY
My Car: 2004 Prius Model: Package: #9 Thanks: 44
Friends: 2 | I've used Jiffy Lube for years and have never had a problem. If you go in there clueless, they're going to try and sell you all these additional services. I always check the level before I leave. I watch them put in the oil (synthetic) and I make sure they have a little left in that last quart. I haven't had any issues and I am on a first name basis with the person that manages the store I go to. BTW... what is wrong with an ex-con or teenager changing oil. Do you want the oil changed by a silver haired guy with a PHD in &*^%@#$$$???? |
| | #33 | |
My Car: 2004 Prius Model: Package: B Thanks: 141
Friends: 15 | Quote:
The horror stories and the hidden undercover camera investigations don't leave me with any warm and fuzzy feelings, that's for sure Could be, they are trying extra hard then. If you're just some schmuck off the street, as long as they get you in and out with as little effort as possible, good enough for them | |
| | #34 |
| Senior Member Join Date: Jun 2005
Friends: 2 | My Doge Cummins diesel in addition to the milage counter has a fuel dilution monitor that will turn on the change oil lamp sooner if needed due to >5% fuel dilution. The Prius is dumb in comparison and needs to be reset. With regard to Jiffy lube service, I took my truck in to jiffy lube to remove the oil filter. It was it's first oil change and the factory gorilla must have used a 12 foot long wrench to tighten it down. I couldn't even budge it. They worked on it for 2 hours finally resorting to a punch through the side of the filter to get it off. They charged me nothing... that's right... 0 charge because it took so long. 12 quarts of heavy duty diesel oil included. I gave them the replacement Fleetguard filter because I didn't want a cheap Fram filter on my 54,000 $ truck.. I can't find any fault with Jiffylube!! -Paul R. Haller- |
| | #35 | |
| Tree-hugging Vegan Witch Join Date: May 2007 Location: Grays Harbor, WA, USA
My Car: 2007 Prius Model: N/A Package: Base Thanks: 718
Friends: 73 | Quote:
However, the Prius only gets changed by US, at home. | |
| | #36 |
| Chicagoland Prius Guy Join Date: Apr 2009 Location: Chicago
My Car: Other Non-Hybrid Model: N/A Package: N/A Thanks: 18
Friends: 13 | Keep looking. I will disclose some stories from my side of the fence. 1) Jiffy lube guy brought out his little white card to show me the color of my fluids. Included on this card was the front differential fluid of my (now ex) girlfriend's Isuzu Axion 2WD. In case anyone missed it, it is 2WD, it doesn't have a front differential as it is rear wheel drive. After looking at him suspiciously, I told him to go ahead and replace it. After waiting a few minutes for him to come back realizing his mistake, he came back with the bill. He charged me for the service. I asked him to show me exactly how he changed it. He refused saying i wasn't allowed in the back due to insurance regulations. At that point, I asked to speak to the manager. Manager said, after I had kindly pointed out that the vehicle doesn't even have the fluid they supposedly changed, offered my my next oil change on them. I declined and walked out without paying a cent. 2) A good customer of mine purchased a new car from 2 months prior. Our service department was closed on saturday, and he was taking his car in a long trip. Wanted the oil change done before he left. Against my advice, he took it to jiffy lube. Where they forgot to replace the drain plug. My customer called me and asked if we offered loaner cars since his 3,000 mile engine was now seized beyond repair. I politely told him he needed to contact Jiffy Lube and ask them the same thing. 3) I need to remove my shoes when someone asks how many times Jiffy lube has cut us a check for engine replacement when one of their employees has neglected everything from replacing the drain plug, the oil filter, or even the cap at the top of the engine. In fact, one time a JL tech slammed the hood down on the cap and broke it. He told the customer that everything will be fine and to drive to the dealership to buy a new one. By the time the customer got to our store, oil had sprayed out of the valve cover and was dripping from every wire, every part, every piece of metal under the hood. I am sure that there are some reputable Jiffy Lube dealers out there. Not every one can be bad. But given the fact that you can be hired at 16 years old, have no prior knowledge of vehicles, and aren't required to pass a test covering the difference between a lug nut and an air filter, I just don't trust any of them at this point.
__________________ Jeff Balcer Pauly Toyota Crystal Lake, IL Google Voice #: 815-575-9550. It will ring my cell and office at the same time. |
| | #37 |
Friends: 15 | |
| | #38 |
| Senior Member Join Date: Mar 2009 Location: new york
My Car: 2006 Prius Model: Package: #2 Thanks: 7
Friends: 3 | A good friend of mine (against my advice) built a quick lube/ car wash facility that he is loosing his shirt on. He has no experience in retail or cars. He had an operator run the place for a few months, and was loosing more & more each month. He closed the place after being open for less then 6 months. 6 months later he opened only the lube section. He hired some people that supposedly had experience. One day he calls me, and asks what to do. His latest oil change guy forgot to put the oil in the car, and he is now being sued by the customer. I told him to terminate the employee, and asked him what training he gives he employees? Does he have a check list of things that the employee must do when servicing the vehicle? Of course, he did not. No wonder he has problems, and upset customers (ex customers). I am sure there are well managed Jiffy Lubes and other quick lube facilities, and poorly managed ones. Ask the manager what the work flow is for the oil change. It is also best to watch what the technician does. Of course, with all this effort, you could do it yourself, and know it is done right, and save some time. (which is what I do.) That reminds me of another friend, who drained the transmission fluid and added 4 quarts of oil to the engine. Sorry about that engine. Are any quick oil change places ISO certified? |
| | #39 | |
Then directly behind the engine is the automatic transmission, with a large black oil pan, a very obvious drain plug, and a teeny plug, which is the overflow drain used for checking the transmission fluid level There have been folks who pulled the wrong drain plug, and suddenly red fluid is pouring out. Oops. You really need the shop manual to figure out the correct refill procedure, the transmission has to be brought up to the proper temperature, and its a PITA to get that just right And, of course, there were folks who did manage to accidently drain their FJ auto trans, and decided the WS fluid was just a bunch of BS. They put in whatever Dexron they had sitting around, and then wondered why the transmission was shuddering and slipping
__________________ 2007 Toyota FJ Cruiser 5AT "C", Sun Fusion | |
| jiffylube, light, maint, required, told |
| Ok: Whatpage In The 2008 Owners Maual For The Reset Of Maint. Required? | ski.dive | Gen II Prius Main Forum | 2 | 06-18-2008 12:45 PM |
| How to Reset Maint Required Icon | Seagull6 | Gen II Prius Main Forum | 16 | 10-05-2006 09:37 AM |
| Just over 4500 miles - Maint Required light blinks | Jeannie | Gen II Prius Care, Maintenance and Troubleshooting | 5 | 09-30-2006 03:09 PM |
| Maint Rec light....06..? | OUscarb | Gen II Prius Main Forum | 1 | 03-09-2006 09:00 PM |
| Maint Required Icon | Nice_Rumble | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 02-25-2006 06:16 PM |
