Battery Replacement - Economy Method
| | #21 |
| Senior Member Join Date: Mar 2009 Location: new york
My Car: 2006 Prius Model: Package: #2 Thanks: 18
Friends: 3 | I guess I do too much risk mitigation at work, so at home, I take the opposite approach. ( I design medical equipment, some risk, and plenty of mitigation). I will keep my eye on the battery though, but then again I am only one data point, so the statistics aren't meaningful. |
| | #22 | |
My Car: 2012 Prius Plug-in Model: Plug-in Base Package: Base Thanks: 651
Friends: 6 | Quote:
| | #23 |
Friends: 3 | I've been using the battery for over a year now, still A OK. |
| | #24 |
| Member Join Date: Nov 2010 Location: Mobile, AL
My Car: 2006 Prius Model: N/A Package: No Package Thanks: 7
Friends: 0 | After reading all the battery posts...I decided to check the 12 volt charge on our newly acquired 06 Prius. After sitting overnight and with everything off I had 11.9 volts. Turning on the lights and a/c blower brought it down into the 10 volt range within 7-10 seconds. I'm new to this Prius thing...but not new to mechanics. So I figure the battery is toast! If it were in a conventional car...it probably wouldn't start the engine. Based on recommendation of the Forum, I ordered the Optima kit from eLearnAid.com. Although I'm sure I could have found a cheaper...lesser expensive...way to go, I believe that time is money and there is a measure of satisfaction in the non-economy method! ...not that there's anything wrong with that! I will report back on the delivery and installation.Thanks to the group for such great information...appreciated!
__________________ Mobile, Alabama, USA 1st Prius...New Owner: 2006 Silver Pine Mica, 82,000 miles 2nd Prius...Still a newbie: 2008 Silver Pine Mica, Touring, 80,000 Last edited by FlyboyTR; 12-04-2010 at 10:25 PM. |
| | #25 |
| Member Join Date: Dec 2007 Location: California
My Car: 2005 Prius Model: Package: #2 Thanks: 31
Friends: 1 | What's your display reading on the Prius? How's you MPG? I'm looking into using a U1 Wheelchair Battery(12V 35Ah), AGM. Thanks. BTW, there is a Sealed version of the your battery. It also has 330 CA. Last edited by wildbottom; 02-02-2011 at 02:42 PM. |
| | #26 |
Friends: 1 | BTW, if anyone interested in Economy Method and want the safer approach, you can buy Batteries Plus SLIU1HP lawnmower battery for $37. It's a Sealed Flooded battery with Vent. (Might need special tube or straw).Link If you're afraid of spillage, you can put it in a Marine Battery Box($13). Only problem with Lawnmower batteries is that they don't last as long. 2 years in general, maybe 3 if they are well maintained. Last edited by wildbottom; 02-08-2011 at 01:28 AM. |
| | #27 |
My Car: 2004 Prius Model: N/A Package: Base Thanks: 265
Friends: 36 | My mum has a rechargable electric lawn mower, the battery generally lasts about 5 years. Of course the battery in that is too big for a Prius. |
| | #28 |
| Junior Member Join Date: Mar 2005
Friends: 0 | How's the economy battery replacement holding up. need to replace mine. (2005) Please advise. Thanks, Vincent |
| battery, economy, method, replacement |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/66601-battery-replacement-economy-method.html | ||||
| Daox's 2004 Toyota Prius Build Thread - Page 12 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com | This thread | Refback | 05-08-2011 10:31 PM | |
| FOB battery replacement - how & when | john1701a | Gen II Prius Care, Maintenance and Troubleshooting | 34 | 06-26-2011 12:47 AM |
| Battery Replacement? | sdgeiger | Gen II Prius Care, Maintenance and Troubleshooting | 11 | 11-09-2010 08:48 AM |
| Method to extend Hymotion Battery by 25% | rwyckoff | Gen II Prius Technical Discussion | 12 | 10-20-2008 10:51 PM |
| Loss in Fuel economy and battery going down | ter426 | Gen II Prius Fuel Economy | 2 | 07-11-2008 08:15 PM |
| 12V Battery replacement | DLangdon | Gen II Prius Care, Maintenance and Troubleshooting | 2 | 01-03-2007 10:39 AM |
