| This is a discussion on Fuel filler pipe replaced when new - pre TSB EL010-04 within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; First off, I am impressed that Toyota has every SSC update in their central computer. Mine has been to 3 ... |
| Member Join Date: Jan 2004
Friends: 0 | First off, I am impressed that Toyota has every SSC update in their central computer. Mine has been to 3 different dealers and the tech showed me the on-screen record. I inquired about getting the TSB EL010-04 (fuel gauge inaccuracy) finally done on my car and was also suprised to learn that my fuel filler pipe had been replaced before I even picked up the car when it was new (on 10/5/03)! Apparently they had some sort of problem with the shape of the original pipe - something about not being able to fit nozzles in properly. Looked around for info, didn't see any. Someone may have already reported this... |
| Senior Member Join Date: Feb 2005 Location: Circleville, Ohio
Friends: 1 | Yes TIS is a big help to us techs. Every used car gets checked for outstanding SSC's and when I get a customers Toyota in for a recall,I can input the VIN and find out if it has any other recalls not completed. To sit down and go thru the TIS would take a whole weekend,maybe. There is a wealth of info on there. |
Friends: 0 | 10/2003? I thought the fuel tank problem came out way after that. |
Friends: 1 | Yes that is odd,DanMan. The TSB EL010-04 for that didn't come out till Aug 24,2004. Then again this is a revised TSB I'm looking at. Not sure when original one was released. Maybe his dates are wrong? Or it was done before the TSB came out? Makes you wonder But then with a prod date in 03,it must be a very early one,which would mean he got the filler pipe and new meter assembly. |
Friends: 0 | That was my question (or realization). There was some sort of filler pipe issue before the TSB came out. Picked the car up in 10/03 (manufacture date 9/03) and the work was done right before pickup. My VIN still places me under the TSB and I have to have another filler pipe/meter put in (I still have the inaccuracy). |
| Senior Member Join Date: Jul 2004 Location: El Paso, TX
Friends: 0 | |
Friends: 1 | <div class='quotetop'>QUOTE(removeum\";p=\"71649)</div> Quote:
It has to do with 04-05 Check Engine Lights on with "No Start" issues. :wink: | |
Friends: 0 | 8) rick57, Yea I know, but I did not know where else to put it. Ben |
My Car: 2004 Prius Model: Package: #9 Thanks: 1
Friends: 0 | I had the TSB EL010-04 done Saturday. They ordered the gauge set to 22,000 miles, so I gained back about 290. First fill-up Sunday, and I couldn't judge how much was needed since the MPGs reset during the install. Gauge had 3 bars, and I tried listening near the now-gasketless opening for gas to gurgle up, but some kinda quietly poured out before I could stop it. Another learning curve, I guess, and hopefully better refueling stops as time goes on... |
| Uel gauge and filler pipe replacement | marjam | Gen II Prius Technical Discussion | 1 | 06-26-2006 07:22 PM |
| Fuel Gauge/Fuel Filler Pipe | galaxee | Toyota Prius Service Bulletins - TSBs | 7 | 04-04-2006 09:59 AM |
| Fuel Tank Filler Neck Seal | ECHOSYS | Gen II Prius Main Forum | 1 | 01-08-2006 07:41 PM |
| Fuel Filler TSB Success, Anyone? | swoozle | Gen II Prius Care, Maintenance and Troubleshooting | 29 | 12-11-2004 02:18 PM |
| My first tank after EL010-04 fuel gauge update | JHartman | Gen II Prius Care, Maintenance and Troubleshooting | 2 | 10-20-2004 08:07 PM |
