| This is a discussion on 2008 rattle at highway speeds within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have a 2008 base Prius which now has 34,000 miles on it. Just recently it developed a rattle at ... |
#1 |
| Junior Member Join Date: Aug 2009 Location: Fort Lauderdale, Florida
My Car: 2008 Prius Model: N/A Package: Base Thanks: 0
Friends: 0 | I have a 2008 base Prius which now has 34,000 miles on it. Just recently it developed a rattle at highway speeds which appears to come from the left hand end of the dashboard. I took it to the dealers yesterday and they told me that it was the ABS pump located under the hood. They also said that many Priuses have this rattle and that Toyota are aware of it but have not issued a recall and will not replace this pump under warranty. Does this mean that I am stuck with this rattle for as long as I own this car?. As you can see I do a lot of miles and cannot envisage being stuck with this annoying rattle for ever or keep my speeds under 65 mph. I find this very difficult to believe. Has anyone else experienced this rattle or can anyone be of help? John Scales |
| Senior Member Join Date: Mar 2008 Location: Scottsdale, AZ
Friends: 1 | No, I haven't heard the rattle ... yet. I have the 2008 Touring model but I only have 10k miles on it. But thank you for telling about the ABS pump. It will be interesting to see what Toyota does about it. |
| Member Join Date: May 2008 Location: Kent, WA
My Car: 2008 Prius Model: Package: #4 Touring Thanks: 0
Friends: 3 | I also have a 2008 Touring Pkg #4 and I've got 23,000 miles so far. I drive mostly highway going to and from work, about 34 miles one way. I haven't experienced this rattling yet and I too am annoyed by things like that. Have you tried calling Toyota and complaining? |
Friends: 0 | Have you tried pressing on the dash when the rattle occurs to see if you can get a better location? I have serious doubts about the dealer's story. |
| Member Join Date: Jul 2009 Location: MD
My Car: 2008 Prius Model: N/A Package: #6 Thanks: 0
Friends: 0 | I to have an 08 prius. i also have this rattle sound that happens. It probably started a couple weeks ago. i have 40k miles on my prius. the noise happens speratcily but usually at speeds over 30 mpg. i have not been to the dealer yet because it is not constant. But it definitively comes from the top left side of the dash and no its not the normal sound the prius makes (capacitor discharge i think it was explained to me when i bought the car). next oil change i will bring it up. |
Friends: 0 | I have tried pressing on the dash, hitting it, trying to reposition the air grill, all to no avail. Those tactics do not change the pitch or nature of the rattle. |
Friends: 0 | |
| Junior Member Join Date: Jun 2008 Location: North Carolina
Friends: 0 | I have one too!! 10K miles and I hear it off and on over 20 mph...but that varies depending on the quality of the road. It is also on the left side and it gets much quieter when I push on the dash next to the air vent. There are photos in another section of the Chat on replacing the radio that shows how to remove the dash, but I am going to a dealer for the next oil change and have them do it under warrenty - with a printout of all these complaints to counter their expected response that this has never happened to anybody else!!!! Unless someone tells me it is very easy to pull off the sections of the dash to see what is loose. |
Friends: 0 | |
Friends: 10 | The brake accumulator pump noise is a buzzing or rattling sound from under the dash on the drivers side. The sound is intermittent, and usually occurs after the brake pedal has been depressed. It lasts for about two seconds at a time. A continuous rattle from the dash will be just that: dash rattle. This is fairly common with the Prius and it means you have one or more loose fasteners under the dash. Some people fix this by replacing the fasteners, sometimes they add small pieces of padding. Either way you have to dismantle the dash. Tom |
| 2008, highway, rattle, speeds |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/67526-2008-rattle-highway-speeds.html | ||||
| Everything about toyota troubleshooting - Yahoo! | This thread | Refback | 08-20-2009 10:06 AM | |
| Refusal to 'glide' at highway speeds? | shtinkypuppie | Gen II Prius Technical Discussion | 6 | 04-02-2009 06:02 PM |
| DTC P0138 at highway speeds | Prius Pete | Gen II Prius Care, Maintenance and Troubleshooting | 21 | 04-22-2008 06:48 PM |
| Prius sways at highway speeds | richard schumacher | Gen II Prius Care, Maintenance and Troubleshooting | 2 | 11-25-2007 02:24 PM |
| Prius shaking at highway speeds | javester | Gen II Prius Main Forum | 8 | 05-24-2006 07:22 PM |
| Beste speeds (climbing,highway) | diemonde | Gen II Prius Main Forum | 4 | 04-19-2006 10:56 AM |
