This is a discussion on 2001 Prius - dead battery with continuous horn within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by Patrick Wong My guess is that the inverter has failed. If so, then the dealer will probably ...
LinkBack (1) Thread Tools
Old 09-24-2009, 02:07 PM   1 links from elsewhere to this Post. Click to view. #21
NYCpriusdriver
My Car: 2001 Prius
Default Re: 2001 Prius - dead battery with continuous horn
Originally Posted by Patrick Wong View Post
My guess is that the inverter has failed. If so, then the dealer will probably charge you around $3K to replace it.
An alternate approach would be for you to buy a salvage part for $1K and install it yourself.
I really hope it's the fusible link and not the inverter. The 100A DC/DC fuse visually looks okay but the link could be blown somewhere else, right? I could maybe see spending $1K and installing it myself but spending $3K on a car I hardly drive these days seems a bit much. Since I had to replace three fuses already, I assume there's the possibility of another one somewhere I missed. I can see how hooking up the jumpstarter battery while the key was "ON" might have blown some fuses, but to take out the whole inverter? And would it be likely to go bad from just sitting around and not getting used for a month at a time?
Anyone know of a direct relationship between nothing coming on when the key is on ACC and the inverter being bad?
NYCpriusdriver is offline
2001, battery, continuous, dead, horn, prius
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/68588-2001-prius-dead-battery-continuous-horn.html
Prius Dead Battery on Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 09-30-2009 09:28 AM
How to start a Prius after long term storage (HV battery dead, replaced dead Aux battery). edli Gen III 2010 Prius Care, Maintenance and Troubleshooting 3 08-05-2009 09:36 PM
2001 Priuses and their dead batteries mellonius Gen II Prius Main Forum 8 04-30-2009 11:46 PM
2001 Battery DEAD, can a prius still run? jamerz52 Gen II Prius Technical Discussion 20 12-20-2008 01:09 PM
2001 Dead Prius ali-rkfd Gen II Prius Care, Maintenance and Troubleshooting 2 10-15-2008 09:33 AM
Continuous battery charging! lafolet3 Gen II Prius Main Forum 5 02-05-2007 01:11 PM
