This is a discussion on Under Hood Fuse Box within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I'm having a bit of trouble figuring out how to open the fuse box under the hood. It's not that ...
Under Hood Fuse Box
Old 03-17-2005, 08:11 PM   #1
cha95sim
Default Under Hood Fuse Box
I'm having a bit of trouble figuring out how to open the fuse box under the hood. It's not that apparent from the manual and I don't want to break something. I would appreciate any helpful hints
cha95sim is offline
Old 03-17-2005, 08:33 PM   #2
8AA
8AA's Avatar
You're not alone. I've had the fusebox cover off two times, and I'm still not sure how it's supposed to come off. The tabs at the top were easy to see and release, but the ones at the bottom sure don't want to let go. I just pushed it down and twisted some and it eventually released.
Sorry I can't be of more help.
8AA is offline
Old 03-17-2005, 10:06 PM   #3
andyprius
I used a screwdriver on the most difficult two tabs and the taped over them for future ease in removing. Most ornery tabs are closest to left fender and most forward. The most inner tab is easiest to get to and I pry from bottom with finger. Holds fine with tape over and much easier to remove. Not being able to R&R total assy. to inspect I can't figure out exactly how they work either? (except with difficulty).
andyprius is offline
Old 03-18-2005, 03:39 AM   #4
KMO
Package: T Spirit
It comes off really easily if you just release the catch on the short bottom edge. Then it hinges straight up and off.
IIRC, you just push in a bit of plastic above the lower catch, and the catch is released.
KMO is offline
Old 03-19-2005, 11:10 AM   #5
cha95sim
Default Re: Under Hood Fuse Box
Thank you KMO. By simply pressing on the plastic latch on the narrow end of the fuse box (toward the front of the car), the box unsnaps and lifts straight up. I don't suppose I would have discovered this without your tip.
Regards,
cha95sim is offline
Old 03-19-2005, 12:11 PM   #6
bookrats
bookrats's Avatar
The fuse box was one of the reasons I feel I got my money's worth from renting a Prius for a weekend, while I was waiting for mine to arrive.
I felt no compunction at all about opening the hood, the fuse box, etc., of a rental, to figure out where everything was. (I had the "new car checklist" form, and wanted to know what I should be looking for before mine arrived.)
bookrats is offline
Rear Hood Latch closed but hood is open Bluebell Gen II Prius Care, Maintenance and Troubleshooting 1 11-16-2007 07:21 PM
Which Fuse Covers the NAV? LOLGuy Gen II Prius Audio and Electronics 4 10-15-2007 07:22 PM
What Fuse Does The NAV Map To? LOLGuy Gen II Prius Technical Discussion 0 10-14-2007 10:32 PM
Fuse box nwpa Gen II Prius Care, Maintenance and Troubleshooting 4 03-29-2007 05:29 PM
Fuse Box Opening green4evr2003 Gen II Prius Care, Maintenance and Troubleshooting 2 01-21-2004 03:47 PM
