This is a discussion on My Prius is in the Shop within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Well today I was driving along and suddenly it says "problem!" in the MFD and the tiangle with the ! ...
Old 03-18-2005, 09:40 PM   #1
babsrocks
babsrocks's Avatar
Default My Prius is in the Shop
Well today I was driving along and suddenly it says "problem!" in the MFD and the tiangle with the ! inside came on. Then ICE would not come on and the battery was being drained fast.
I pulled over and called the dealership, I got it up there and they said the computer needed to be re-programed.
This ever happen to anyone else?
babsrocks is offline
Old 03-18-2005, 10:25 PM   #2
TonyPSchaefer
Your Friendly Moderator
TonyPSchaefer's Avatar
Friends: 23
I'm sure someone will be of more help, but use the Search page. Look for things like "red triangle". Just on a lark, was it raining or wet?
TonyPSchaefer is offline
Old 03-18-2005, 10:27 PM   #3
babsrocks
babsrocks's Avatar
<div class='quotetop'>QUOTE(TonyPSchaefer\";p=\"73758)</div>
I'm sure someone will be of more help, but use the Search page.  Look for things like \"red triangle\".  Just on a lark, was it raining or wet?
No, it wasn't raining or wet, actually the best weather we've had in awhile. Dry sunny and in the 40's.
Old 03-18-2005, 10:38 PM   #4
TonyPSchaefer
Friends: 23
Well, the dry weather eliminates thoughts of water or vapor getting into a loose seal (was an issue at one time). I just ran a search using "red triangle" and got a full page of results. I was going to flip through and see what I could find for you, but I'm sure you would be better at finding something that better matches your experience. And you can also read the responses and follow-ups.
One things for sure: Suggest to your dealer that they pull the error codes from your car. But know this: with some dealers, if you ask that they pull the codes and they don't find anything they will charge you for the labor. But if they do find something then they don'tcharge you. So perhaps there might be a way to "suggest" that they pull the codes without actually requesting it...
Sorry for trouble. Keep us posted.
Proud father of Priapus: the '04 Tideland BC9 with an OEM EV button and sense of self-righteousness
Current Mileage
Chicago Prius Group Website
Chicago Hybrid Group on FaceBook
Find me on faceBook
Old 03-18-2005, 10:42 PM   #5
Friends: 37
Your ECU needs to be 'flashed'. This is a fairly well known and easily fixed issue and usually doesn't recur (with or without the ECU flashing). BTW, you could have restarted and driven the car without any further problem (more than likely...assuming it is the well known problem and not something worse).
efusco is offline
Old 03-18-2005, 10:46 PM   #6
babsrocks
babsrocks's Avatar
Well they have it overnight. They told me to bring it in when I called. They had it for about a half hour and said I shouldn't drive it until they could reprogram the computer. I don't know exactly what the problem was, but I expect a full report in the morning.
They were however nice enough to give me a loaner for the night. it's a Chevy Silverado 1500 Quad cab, a big difference from the Prius, that's for sure!!
When I find out what the problem was, I'll let you know.
I'll do the search and see what comes up.
I didn't get a manual with the car, but I hope to have one soon.
I'll keep you posted.
Old 03-19-2005, 12:38 AM   #7
rick57
Default Re: My Prius is in the Shop
I agree with Evan in that the ECU needs reflashed. All will be ok after they do that,I have never had one return after reflashing. And like he said,it is fairly well known and your dealer should have you up and running in no time. By the way,the Chevy was full of gas,wasn't it? You should have fun watching the gas gauge drop after driving your Prius,
rick57 is offline
Old 03-19-2005, 04:16 PM   #8
babsrocks
babsrocks's Avatar
OK, I got my Prius back.
My receipt says:
Tech retreived code P3191 and POAOF, current ECU Cal is 34702000 reprogramed ECU per bulletin EG047-04 to new cal at 34705100.
So if that means anything to anyone......
I am very happy to have my car back, the Silverado was huge and thirsty! They told me to return it with as much gas as it had when I got it, so before I dropped it off I but $5 in, not nearly enough, it didn't even move the guage any, in my Prius that would have been almost a half a tank!
So thank you everyone.
Old 03-19-2005, 04:50 PM   #9
rick57
Yes that is the common TSB for the 04/ early 05 Prius'. You should have no problem with that now. Drive and enjoy.
With your time in the Chev, I bet your glad you don't have to fill it weekly, haha. I have a 99 Tahoe my wife drives and loves so believe me,it doesn't get the mileage you guys/gals do in your Prius'. Now if I could just talk here into a new Highlander hybrid, hmm?
rick57 is offline
Old 03-19-2005, 06:30 PM   #10
V8Cobrakid
Friends: 5
my car is in the shop right now for the center console material to be replaced and have my brake light switch recall done. I hope my car doesn't need this flash too. i guess time will tell
instead of my lovely prius, i'm driving a Dodge 1500 truck with a Hemi engine. 345 horsepower 14 mpg at best. about 12 to 13 on average. *shrug* i don't want to have to add fuel to this thing.. but.. i'll have to
a very crappy vehicle for costing more than my prius.
V8Cobrakid is offline
Dont buy from the Prius shop on here (Now the PriusChat Shop Lovefest thread) dogtrainer Gen II Prius Main Forum 69 07-23-2008 03:01 PM
I had my Prius 10 hours and it's already in the shop Metalkitty Gen II Prius Technical Discussion 31 09-04-2007 05:32 PM
prius chat shop sonny Gen II Prius Main Forum 1 11-22-2006 06:45 PM
My Prius is in the shop for a couple days priusham Gen II Prius Main Forum 8 11-01-2005 01:03 PM
Prius Accessories Shop Nda3rdCar Gen II Prius Main Forum 0 12-31-1969 07:00 PM
