This is a discussion on Brake “hiccup” sound. within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Brake “hiccup” sound. My wife and I went on a one day fun drive last Friday. We drove up into ...
Old 03-20-2005, 10:07 PM   #1
Sufferin' Prius Envy
Platinum Member
Default Brake “hiccup” sound.
My wife and I went on a one day fun drive last Friday. We drove up into the Sierra, and up and down several passes . . . 300+ miles in all. The car did just fine, but when we pulled into a casino at South Shore, Lake Tahoe, we noticed that a “hiccup” sound coming from the area under the dash or engine compartment. The “hiccup” would occur when the pedal was slightly pressed, and had nothing to do with how hard the pedal was pressed. The sound was NOT the booster pump, and there were never any warning lights. To me it sounded like the actuator was releasing pressurized fluid with entrained air. (Not a mechanic’s ear here.)
On some of the downhill grades I applied the brakes for long periods for speed control, but not hard enough for the mechanical brakes to engage - just hard enough to increase the regen.
The sound continued for the rest of the trip, but the next morning back in Sacramento - elevation 17 feet - the sound had gone away.
I am of course curious . . .
Was it altitude induced?
Did I overheat the brake fluid and induce air into the system?
Should I not have used the brakes for that long a period? (I know about the “B” Engine Braking mode . . . but that was overkill in that it would slow down the car too much.)
Anyone else have brake hiccups???
My words are my word. I refuse to actively participate in any forum where my written words can/are changed by the powers that be. If you don't like what I wrote, delete it – but don't put words in my mouth that aren't mine.
Good-bye.
Old 03-21-2005, 01:23 AM   #2
xevious
I think I've had the same thing happen... Hadn't thought to ascribe a biological function to it, though...
I live near sea level, but every time I visit my family in the high Cascade desert (high elevation and colder), the brake system or brake pedal makes a vibration noise when I depress the pedal. The sound is similar to rubbing an inflated latex balloon.
Absolutely no idea what is causing this, but I would also like to know. The service center was not able to get my brakes to "hiccup" - perhaps the rather savage-looking technician scared the hiccups away.
Anyone else?
xevious is offline
Old 03-22-2005, 01:29 PM   #3
200Volts
We just went to Reno-Truckee from Sacramento and noticed the same noise as I released the brake from a dead stop. Temp was 34F and we were sitting for 3 hours in stop & go traffic. Back at Sacramento there was no noise.
200Volts is offline
Old 03-22-2005, 05:22 PM   #4
MiamiMurphy
Hi -
Thought I was imagining things but I also have started to hear this noise after driving in hot conditions and heavy traffic - I do not hear it all of the time but it does seem related to the brakes.
Let me know if you find a solution.
Thank you.
ML
MiamiMurphy is offline
Old 03-22-2005, 07:46 PM   #5
prius mdt
Default Re: Brake “hiccup” sound.
First - I dunno - I've never heard a Prius do the hiccup thing - so this is at best an educated guess...here goes.
Any Toyota with B/A (brake assist) including the Prius has an accumulator with pressurized brake fluid. In the event you are in a panic stop and did not use enough force on the pedal to induce ABS operation, the store of pressurized fluid will be released into the brake system to induce ABS and thusly bring the vehicle to a shorter and more stable stop.
As you drive - (and it sounds like heat in the brake system - which relates to heat in the brake fluid) - pressure can change in the BA accumulator - if heat increases, pressure increases, and the system will bleed off some pressure to return the sytem to a proper level. Is it possible you are hearing this pressure bleed during these events? - Just a theory ... Food for thought...
Don - Toyota Master Diagnostic Technician
prius mdt is offline
Old 03-22-2005, 10:22 PM   #6
xevious
Not for me. The sounds occurs when the vehicle is cold, and seems to go away after driving for 20 minutes or so. Cold and high altitude are the only two significant possible contributing factors in my case, although neither may be responsible.
My situation (and this has happened on three occassions) is this: drive from the Oregon valley to Central Oregon in the winter. Park overnight. Starting with the next morning, the brakes will make a strange noise any time I drive my Prius in that area. Problem goes away upon returning to the soggy, warmer valley.
The sound itself is much akin to rubbing an inflated latex ballon, and occurs when lightly depressing the brake pedal. The sound is not well correlated with the physical pedal displacement, but seems to be generated by an automated part of the brake system.
My evidence for this statement is that the sound is highly stereotyped - it sounds the same regardless of how slowly, quickly, delicately, or forcefully I depress the brake pedal.
Any ideas??
xevious is offline
Old 03-23-2005, 12:10 AM   #7
HTMLSpinnr
Gen III Forums Moderator
HTMLSpinnr's Avatar
Friends: 18
Some of us have reported (and some dealers are aware) of high altitude/cold weather combinations bringing out a brake system noise. I'm not aware of any fixes though. It was an annoying, if not embarrasing addition to an otherwise nearly silent car.
HTMLSpinnr is offline
Old 03-23-2005, 02:57 PM   #8
xevious
Thanks, Rick. Glad to know that I'm not alone.
I'll give Toyota a call and report this as well. Better safe than sorry if it turns out to be a defect.
xevious is offline
Brake clunk sound on 2007 Prius LACraig Gen II Prius Care, Maintenance and Troubleshooting 4 12-10-2008 12:44 AM
ABS brake warning on 2007 Prius leading to brake failure adk235 Gen II Prius Care, Maintenance and Troubleshooting 4 08-05-2008 07:02 PM
Odd Sound heimdm Gen II Prius Main Forum 17 10-04-2006 12:31 AM
No sound from XM! MarieH Gen II Prius Audio and Electronics 4 07-25-2006 01:58 AM
that PSD sound john1701a Gen II Prius Main Forum 6 05-14-2005 02:50 AM
