This is a discussion on A Question About Towing... within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have a question concerning moving or towing a "dead" Prius. In the building where I live, I park in ...
Old 03-21-2005, 11:06 AM   #1
canuckican
Default A Question About Towing...
I have a question concerning moving or towing a "dead" Prius. In the building where I live, I park in a very low underground parking structure with very little room on any side. Let's assume I park nose-in in my parking spot. I then have a large pillar on my driver's side, a wall in front of me, another car on my passenger's side, and a pillar on the other side of that. I have tried to include an attachment map which details this layout.
Assume that the Prius "died" such that I could not get the computer or MFD to turn on - as some people have reported here. If I cannot turn the car on, I cannot shift it into neutral, correct? If I cannot shift it into neutral, how are they going to move the Prius in this configuration (note the front wheels are not available to be lifted by a tow truck due to the wall)? Would the car have to be dragged backward out of its spot to get it to a point where the front end could be lifted? Would that not be very traumatic on the car?
I am seriously wondering what would happen in this situation. Does anyone have any experience or ides on this?
canuckican is offline
Old 03-21-2005, 11:18 AM   #2
DanMan32
You could lift the front of the car from the side and put the wheels under a dolly. Getting access to the lift point would be tricky.
Otherwise, your only option is to try and boost the car into Ig-On, or else you'll have to drag it a few feet to get to the front of the car.
I would have suggested manually applying power to the parking pawl motor (properly called the shift control actuator), but it is a 3 phase 12V motor.
Preventative solution would be to back the car in.
DanMan32 is offline
Old 03-21-2005, 11:22 AM   #3
canuckican
Default Re: A Question About Towing...
Here is my attempt to attach a jpg map of the parking situation.
Old 03-21-2005, 11:23 AM   #4
Friends: 37
I agree with Dan,
I think it depends upon how "dead" you are. If you are completely electrically 'dead' and it won't go into IG-ON mode to allow you to go into neutral even with a battery boost then you're probably going to have to drag it out. I think the risk to the system are small, but certainly aren't zero.
If, OTOH, you just have a dead 12v there are plenty of battery boosters and jumper cables long enough, to allow a jump start. Even if it won't turn over get it into Ig-On and put it in neutral before dragging.
Evan E. Fusco, MD
efusco is online now
Old 03-21-2005, 11:45 AM   #5
jayman
Whether I'm parked at my condo underground parking or at the underground parking at work, I always like to back into the stall. Just a habit I've always had.
jayman is online now
Old 03-21-2005, 01:49 PM   #6
canuckican
There were some excellent ideas presented here, and of course, the solution would depend upon what has caused the "dead" Prius. BTW, I always back into my spot...so the question was really more a hypothetical. But it could happen to someone else.
Towing dfusrey Gen II Prius Technical Discussion 5 01-07-2007 08:05 PM
Towing with a Prius FJRCRAZED Gen II Prius Main Forum 21 10-30-2006 04:37 AM
Towing a truck! iaowings Gen II Prius Main Forum 17 09-20-2006 03:07 AM
towing question captain archer Gen II Prius Modifications 16 08-31-2006 02:39 AM
Towing ervajv Gen II Prius Main Forum 2 04-13-2005 07:24 PM
