This is a discussion on Tires for the Prius within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have brand new Michelin Harmony Tires 175-65-R14 and the specs can be found on john1701a.com/prius/prius-tires_classic.htm website which was so ...
Tires for the Prius
Old 04-05-2005, 08:24 PM   #11
helloprius
Default Re: Tires for the Prius = I love my new Tires !!
I have brand new Michelin Harmony Tires 175-65-R14 and the specs can be found on john1701a.com/prius/prius-tires_classic.htm website which was so helpful . I wish i knew about these great tires when i changed my 1st set 1.5 yrs ago (with Potenza's) God those Potenza's wear down quickly ! I went through 2 sets before I discovered that I could change them to Michelin's. The Toyota dealer wouldn't do it and neither would the bigger Tire Chain Stores -- so i had a little local tire shop do it for me. They are wonderful so far. I drove over 1K this past weekend in the wet snow and rain. Great handling and steady while I whisked by the big trucks on the highways going 77 mph. Good Luck ! I paid 80 for each tire by the way (install and extra costs not included).
helloprius is offline
Old 04-07-2005, 02:06 AM   #12
dru
<div class='quotetop'>QUOTE(helloprius\";p=\"78847)</div>
I have brand new Michelin Harmony Tires 175-65-R14  and the specs can be found on john1701a.com/prius/prius-tires_classic.htm  website which was so helpful . I wish i knew about these great tires when i changed my 1st set 1.5 yrs ago (with Potenza's)... I paid 80 for each tire by the way
Sounds like you have a first gen Prius. They had low rolling resistance tires where the 2004+ models use "standard" tires. So for me, there's no problem changing them as long as the size is correct. However, I'm still trying to find a store that will trade my Goodyear Integrity tires for the something like a half off deal. No luck so far; looking for advice from veteran pre 500 mi trader-uppers. I'm at 250 miles and counting!
dru is offline
Old 04-07-2005, 11:42 PM   #13
kenmac
Last week I changed my Michelin Energy XV1 tyres to the MXV8 type (195/60 R15).
The reason was because of a damaged tyre and the originals not being available (Oz supply stuff-up) , Toyota paid for three tyres - covered in a previous topic.
It's very early in the experience, but my initial impressions are that they are considerably quieter on rough surfaces (less roar) and seem to provide a softer ride.
Handling seems to be less "twitchy" - may be an illusion, will know when we get some crosswinds on freeway.
It will be interesting to see if the fuel readings will be affected in any way - too early yet of course.
How long they will last is to be proven - they were much cheaper than the originals. (XV1 = $280AU, MXV8 = $192AU)
kenmac
kenmac is offline
Tires For a Prius FL_Prius_Driver Gen II Prius Main Forum 4 09-06-2007 06:20 PM
Prius Tires jstack AZ - Phoenix 5 07-13-2007 01:52 AM
Rotating Tires/ can't get rear tires off filiberti Gen II Prius Main Forum 18 08-31-2006 02:59 PM
What tires 06 Prius Comes With mandargb Gen II Prius Main Forum 1 06-18-2006 04:26 PM
205/60 R15 tires for the prius electricity_guzzler Gen II Prius Modifications 22 06-10-2006 11:39 PM
