| This is a discussion on 2009 wiper arm new design - can not remove? within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I had an earlier thread http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/70763-help-remove-wiper-arm-nut-part-number.html but this topic may worth its own. I contacted a dealer about the wiper ... |
| Senior Member Join Date: Mar 2009 Location: USA
My Car: 2009 Prius Model: Package: #2 Thanks: 246
Friends: 19 | I had an earlier thread http://priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/70763-help-remove-wiper-arm-nut-part-number.html but this topic may worth its own. I contacted a dealer about the wiper arm nut and was warned that the wiper arm base is made of "soft material" such that when it is installed the grooves got cut into it and if the wiper arm is removed then the grooves will be destroyed and I will need a new wiper arm. Any 2009 owners out there removed and replaced their wiper arms yet? |
Friends: 0 | I'm quite certain the wiper arm on the '09 is the same as it has been since '04. |
Friends: 19 | Thanks! Have you removed your 2009 wiper arms and put them back on? If so what's the production date of your 2009? Mine feel like really stuck on which is consistent with what the dealer said. |
Friends: 0 | I have not removed them on my '09. I did on my '04 and they were difficult to get off the spline. You have to make sure you pull them straight off the shaft and not try to pull at an angle. |
| The Following User Says Thank You to firepa63 For This Useful Post: | 2009Prius (10-20-2009) |
| 2009 prius, wiper arm |
| Help remove wiper arm & nut part number | 2009Prius | Gen II Prius Care, Maintenance and Troubleshooting | 2 | 10-17-2009 09:58 AM |
| Rear Wiper Design Correction Modification | Vincent | Gen II Prius Modifications | 20 | 05-08-2006 05:28 PM |
| To remove or not to remove door panels | DBM | Gen II Prius Modifications | 4 | 06-27-2005 10:24 AM |
| 2004 Wiper Design | chris_b_01 | Gen II Prius Main Forum | 11 | 03-17-2005 07:04 AM |
| New Wipers or New Wiper inserts? Driver side wiper size? | Eug | Gen II Prius Care, Maintenance and Troubleshooting | 7 | 01-23-2005 12:45 PM |
