| This is a discussion on Synthetic Oil vs. Real Oil within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I am a new convert and very excited by my 2005 Prius - the design, the technology, the performance, the ... |
Friends: 0 | I am a new convert and very excited by my 2005 Prius - the design, the technology, the performance, the drive, so I am reading up a lot of stuff(sometimes not a good idea) John - his web page : http://john1701a.com has put together a straightforward User-Guide, in which he recommends use of Synthetic Oil over Real Oil. Is this a recommendation worth following? |
My Car: 2004 Prius Model: Package: #9 Thanks: 1
Friends: 0 | The oil in my Prius is real, it's just not anti-synthetic. Semantics aside, I'm not hearing of people crying that they need synthetic to get great mileage, so I'll try to maintain a positive outlook on my synthetic and see if down the road it makes a difference... |
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 216
Friends: 18 | I've noticed mileage exceeding 60mpg using Synth. My average has gone from the high 40's-low 50's to the mid to upper 50's by switching to synth. I'm due for a change (per the light :-/) and I'll put Synth in again. |
| Senior Member Join Date: Jul 2004 Location: Houston Texas
My Car: 2005 Prius Model: N/A Package: #9 Thanks: 0
Friends: 0 | Ian, To sum up the various threads on this subject, it settles down to: 1) How long to do intend to drive your Prius? If the answer is over 100K, then synth oil is a good idea 2) How paranoid are you about the new technology in the Prius? If you are, then for a little extra insurance on the engine, use synth oil. 3) Some folks feel the technology in synth oil is a logical fit with the superior technology in the Prius. 4) And regardless if you use real or synth oil, change your oil at least per schedule. Most dealers say 3-5K miles. How you drive and where you drive can radically effect the life of engine oil. You should always dipstick your oil once a month or 1000 miles to check its' color - if it looks dirty, it generally is. 5) Changing the oil on the Prius is very easy, a lot of folks DIY. Don
__________________ 2005 Prius - Black/Charcoal, Package #6, Leather, Tint, Woodgrain Dash, body side moldings, mudguards, front end mask, Mobil-1 5-30, Chassis stiffening plate, Michelin MXV-4's |
Friends: 0 | If you check out this thread and scroll down about 2/3rd's the way down you'll find a post I made about YC15 and the email I got back from Andrew Grant in there is a note on mileage. http://priuschat.com/forums/2-vt7008.html?...r=asc&&start=20 |
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 9
Friends: 12 | The simple thing to do is ask yourself if it is worth the extra $10 every 5,000 miles. With the price of gas so high now, that difference is becoming rather trivial. |
Friends: 0 | <div class='quotetop'>QUOTE(john1701a\";p=\"75810)</div> Quote:
Friends: 0 | Not sure why you'd change every 5k with syn. Plenty of test data to support it is fine past that. |
Friends: 0 | <div class='quotetop'>QUOTE(popsrcr\";p=\"75816)</div> Quote:
Friends: 0 | <div class='quotetop'>QUOTE(jeepien\";p=\"75818)</div> Quote:
http://www.amsoil.com/lit/g1490.pdf Huh. Now it's annual changes, per page 2... | |
| Synthetic or Not? OIL | Ryn01599 | Gen II Prius Care, Maintenance and Troubleshooting | 23 | 10-28-2008 05:53 PM |
| synthetic oil ? | whitewhiskers | Gen II Prius Main Forum | 5 | 03-29-2007 05:39 AM |
| synthetic oil | SSimon | Gen II Prius Care, Maintenance and Troubleshooting | 14 | 07-14-2006 11:04 AM |
| Synthetic oil | Tadashi | Gen II Prius Main Forum | 11 | 05-05-2005 09:51 PM |
| Synthetic Oil | jryan | Gen II Prius Main Forum | 20 | 01-14-2005 05:52 PM |
