This is a discussion on Do-it-yourself changing oil on the 2004 Prius within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hi, In looking through the owners manual on my new 2004 Prius I could not find anything about changing the ...
Old 12-09-2003, 10:34 AM   #1
steve10brink
Default Do-it-yourself changing oil on the 2004 Prius
Hi,
In looking through the owners manual on my new 2004 Prius I could not find anything about changing the oil yourself. Has anyone done this yet and, if so, are there any extra things to do? Is the oil filter difficult to remove?
Thanks,
Steve
steve10brink is offline
Old 12-09-2003, 12:07 PM   #2
Friends: 41
There are a couple things...
Word is that the filter is no problem.
There is a special 'crush washer' that you need, and you'll need to get the right filter, of course.
John1701A documented his experience with his own oil change on the 2004-YG
http://autos.groups.yahoo.com/group/2004-p...s/message/18321
--evan
efusco is offline
Old 12-11-2003, 05:02 PM   #3
Jerry P
I have changed my oil already - went to Mobil 1 synthetic- and it is one of the easiest cars I have done. The filter is the same one used on the Corolla and Echo, Toyota 90915-YZZA2. You may notice a slight difference in the mounting end of the filter from one you buy here and the Japanese one that comes on the car. Parts dept. said that US made filter is slightly different at the mounting end but it is the right one to use. I'd recommend using only genuine Toyota filters, at least during your 60K engine warranty period. Also, save your oil receipt and mark the mileage and date in a maintenance log book. I am going to install a Fumoto drain valve on mine. This is a neat little valve that eliminates the possibility of stripping out the threads on the oil pan plug. Be sure to replace the 'crush washer' on the drain plug. It is designed for single use and may leak if not replaced.
While you're under the car, take a look at how well sealed all the components are underneath. The build quality of the Prius is beautiful!
Warrior in the Battle for American Energy Independence
Jerry P is offline
Old 01-10-2004, 04:38 AM   #4
green4evr2003
Changing Oil: Soo-o-o-o, can anyone please post the number of the American-manufactured (well, China, Mexico, Sri Lanka, etc.) replacement oil filter?
Bruce Webster
Green4evr2003
green4evr2003 is offline
Old 01-10-2004, 08:23 AM   #5
Jerry P
90915-YZZA2
Jerry P is offline
Old 01-12-2004, 02:39 PM   #6
texassalsa04
Default Jerry P...
"...I am going to install a Fumoto drain valve on mine..." Jerry, have you installed the Fumoto Drain Valve on your Prius yet? I wonder how it looks after you installed it, whether the lever is in an ideal position so as to not get knocked on with rocks and such. Please keep us posted.
I am seriously considering the purchase of the Fumoto valve.
Thanks,
Tony.
texassalsa04 is offline
Old 01-12-2004, 04:26 PM   #7
Jerry P
Yes...I put it on Saturday. My oil level was a little too high so I drained it all and installed the valve. The angle of the drain hole is ideal. The valve does not extend much below the level of the oil pan and the handle is pointed towards the back of the car so stones and road debris shouldn't affect it. It locks in place anyway so I don't think there would be a problem anyway. I think it's a good investment.
Jerry P is offline
Old 01-13-2004, 12:19 PM   #8
texassalsa04
Default Jerry P...
Thanks for the response. If you can snap a picture to show us, that will be great!
Old 01-14-2004, 10:04 AM   #9
ammiels
Fram sells a Gizmo for+/- $12 that purports to do the same thing. When the weather gets warmer here I will look into it. Peace, Ammiel
ammiels is offline
Old 02-07-2004, 07:55 PM   #10
FredWB
FredWB's Avatar
The Fumoto sounds like a great deal. Especially when the gasket is $3.99 each! Do you have to order the valve online?
FredWB is offline
Changing a Prius Wiper Blade Tideland Prius Knowledge Base Articles Discussion 7 10-22-2009 05:27 AM
Changing or "skinning" the Prius interface njdjz Gen II Prius Modifications 7 11-24-2007 07:45 PM
EPA changing its estimate for the Prius WHEN IT SHOULDN'T! PriusTouring07 Gen II Prius Main Forum 42 07-23-2007 11:10 PM
Prius Navigation changing route from speed to distance onlynark Gen II Prius Technical Discussion 13 03-13-2007 06:15 PM
Driftwood Pearl, 2004 BC package, ordered May 7 2004, Fresno knowledgeseeker Order Tracking 0 09-19-2004 09:48 PM
