This is a discussion on how do I change oil HELP within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have the car on jacks and pulled the drain plug with the allen socket. A lot of quite dirty ...
Old 05-17-2005, 03:31 PM   #1
timebum
Default how do I change oil HELP
I have the car on jacks and pulled the drain plug with the allen socket. A lot of quite dirty oil came out but noticed that the oil was red. Opened the hood and the dipstick says the oil is still in the engine. I assume that I drained the transmission oil so I need to know how to refill the transmission and finally, which plug do I pull for the oil? There is a 24 mm plug that I loosened but the fluid that started to come out was so clean that I assumed that it was the trans oil. I need some help!
timebum is offline
Old 05-17-2005, 04:22 PM   #2
bookrats
bookrats's Avatar
John has published a marvelous, step-by-step set of [url=http://john1701a.com/prius/prius-oilchange.htm]oil change instructions (with pictures).
I'd recommend checking this out.
(Sorry I can't be of help, but I haven't ever changed my Prius' oil.)
bookrats is offline
Old 05-17-2005, 04:43 PM   #3
galaxee
resident lab rat
galaxee's Avatar
Friends: 26
the power inverter uses red oil- maye you drained that?
galaxee is offline
Old 05-17-2005, 04:49 PM   #4
raybon
Default Re: how do I change oil HELP
Changed my oil this weekend. The oil pan is near the front passenger side wheel, within easy arm reach. I didn't need to put the car up on stands to do the oil change. The filter was a little difficult because I had to do it by feel, but even that was pretty easy.
Glenn
raybon is offline
Old 05-17-2005, 05:14 PM   #5
timebum
Looked at John's picture site and quickly found the oil drain plug. Still need help identifing what I drained when I pulled the allan plug and how do I get what came out (thick red oil) back in.
timebum is offline
Old 05-17-2005, 07:37 PM   #6
bobc
bobc's Avatar
Any chance you can post a photo of where the plug is that you removed? That may help in identifying if it's the transmission fluid or the inverter...
bobc is offline
Old 05-17-2005, 07:52 PM   #7
timebum
Found out that I had drained the transmission. There is a magnet in the drain plug and mine was VERY full of steel particles. The tranny takes a special "WS" oil which I got at the Toyota dealer. My old oil was very dirty so perhaps this bone headed move on my part may turn out as a small blessing.. Thanks to those who responded. This was my first visit to the site.
timebum is offline
Old 05-17-2005, 09:19 PM   #8
galaxee
resident lab rat
galaxee's Avatar
Friends: 26
bobc- that avatar is awesome. just thought i'd say it.
galaxee is offline
Old 05-18-2005, 08:56 AM   #9
DanMan32
Really dirty huh? Guess I will change it at 60K.
DanMan32 is offline
Old 05-18-2005, 01:03 PM   #10
jayman
<div class='quotetop'>QUOTE(timebum\";p=\"90357)</div>
Found out that I had drained the transmission.  There is a magnet in the drain plug and mine was VERY full of steel particles.  The tranny takes a special \"WS\" oil which I got at the Toyota dealer.  My old oil was very dirty so perhaps this bone headed move on my part may turn out as a small blessing.. Thanks to those who responded.  This was my first visit to the site.[/b]
Could you please tell us how many miles you have on your Prius? I'm asking as it may be prudent to do an early initial change of the CVT fluid and then every 30,000 - 50,000 miles.
As far as I know, the CVT fluid is considered "lifetime" for Prius cars in the United States. Here in Canada, you're supposed to change it every 96,000 km.
BTW: was it hard to fill the CVT? I have an assortment of little hand pumps that fit on top of 1 quart bottles, so I'm glad I saved them.
jayman is offline
When to do 1st oil change? bshef Gen II Prius Care, Maintenance and Troubleshooting 87 05-24-2006 02:36 PM
how much is an oil change (5k, 10k, 15k?) dyyuan Gen II Prius Main Forum 24 12-06-2005 10:34 PM
To make them change or not to change (the oil?) micheal Gen II Prius Care, Maintenance and Troubleshooting 4 08-07-2005 01:21 AM
First Oil Change PriusPhotog Gen II Prius Main Forum 8 06-04-2005 01:53 AM
Oil Change thusband Gen II Prius Care, Maintenance and Troubleshooting 8 04-24-2005 04:22 PM
