| This is a discussion on More Perspectives on the Elusive Fuel Gauge Accuracy... within the Gen II Prius Care, Maintenance and Troubleshooting forums, part of the Gen II (2004-2009) Toyota Prius Forums category; ...last square started blinking at around 480 miles. Went to fill up, managed to get 9.4 gallons in, which is ... |
| Junior Member Join Date: May 2005
Friends: 0 | ...last square started blinking at around 480 miles. Went to fill up, managed to get 9.4 gallons in, which is an average of about 51 m.p.g., which concurs with the computer... I have an '04, no work done with respect to the TSB pinned above, weather has been 60's-70's fahrenheit. Seems reasonable to me... Given, unless anything changes, I really don't think I'll make the time, nor undertake the effort, to get it "fixed"... |
My Car: 2010 Prius Model: N/A Package: Technology Package (Canada) Thanks: 229
Friends: 23 | Mine started blinking at 794kms, I pumped at 818kms. Farthest distance (so far) that I've dared travelling on a blinking light |
| Member Join Date: Jun 2007
My Car: 2007 Prius Model: Package: #3 Thanks: 0
Friends: 0 | I just completed a trip from Florida to New York and averaged 50.2 mpg overall with a loaded vehicle ! I was panicky but made it to a station and put in only 8.3 gals. The MPG for that leg was 50.3. I seriously question the accuracy of the gauge and probably will never trust it again |
| Senior Member Join Date: Apr 2007 Location: Wakefield, MA.
My Car: 2009 Prius Model: Package: #2 Thanks: 5
Friends: 6 | Quote:
| Junior Member Join Date: Apr 2008 Location: Niles, MI
Friends: 0 | I refuel based on miles since last fill, not gauge reading |
My Car: 2004 Prius Model: N/A Package: #6 Thanks: 100
Friends: 0 | After how many miles? If it's 200 you should be fine. If it's 500 you will eventually run out. Pretty much the only way the gauge can be inaccurate about running out is if the last fillup occurred on a sharp slope, which can throw off the tank's tilt compensation. |
| Junior Prius Owner Join Date: Apr 2008 Location: Metro Detroit
Friends: 13 | Speaking of fuel gauge readings, from a FULL tank (according to the pip meter), knock off TWO complete pips and what do you get? 77miles. What does the MFD say? 61 miles of the 77mileage is at 55mpg. Huh, Eeekk, What to do ...What to do? Actually, I'm going to report this to my nearest: No one. One month and one week old 2008 car with only 384(?) mileage and a hardly used fuel bladder, what else should I expect? Fortunately, I have fuel bladder experience in helicopters I flew both in icy weather and in very warm weather (read: Iraq). A helicopter pilot performs an ongoing fuel check/calculation during flight to check fuel drain, never depending his life on a set number of miles or hours or time. Sure, you can guesstimate mileage/time all you want, but understanding that bladders variably contract and expand due to age and temperature and that remaining fuel quantity will change depending on a host of other factors (ex. prevailing weather, headwind, tail wind or sidewind, how much aircraft load, altitude considerations, how much collective the pilot jockeys, etc) makes set mileage figures inaccurate (at the very least) and potentially deadly. Of course, if the fuel gauge is simply bleeding, then you might have a problem. I think some people are having difficulty adjusting to the bladder in a Prius, it's unlike the more straight line automobile fuel tank. There is plenty of good advice from the senior members here, like multiply your overall mpg by 10 to get the mileage figure at which you should fuel up, or just fuel up at 2 pips (this is what I'm doing). I hope this helps at least someone. ZC1 Last edited by ZC1; 06-02-2008 at 11:09 AM. |
Friends: 13 | Quote:
ZC1 | |
Friends: 0 | With 450 miles and 4 pips still on the meter, I think if I had waited until it was down to 2 pips I would have run out of gas by then. I was averaging around 51 mpg at that point. By multiplying 51 x 10 = 510 miles with 4 pips still on the meter doesn't make sense! |
Friends: 2 | I fill up at two pips. I have not yet -- ~5500 mi. -- run out of gas. I have not yet taken a trip "fully loaded." Nonetheless, this summer I probably will take such a trip. I don't want to get caught out of gas on the highway. I'm getting somewhat concerned. It seems to me that when the car is "fully loaded," most of the new weight will be aft and the suspension back there will settle more than at the front. So, there would be the possibility that the combination of the in-tank float valve and the two inclination sensors was not reading the fuel level correctly. I suppose that the combination of an uncalibrated fore-aft inclination sensor and a steep hill -- more likely on secondary roads than on a multi-lane highway -- might cause the in-tank fuel gauge to show greatly more fuel than it really is holding. I'm wondering, would it be advisable at the beginning of the trip, with the car "fully loaded," to reset the tank inclination sensors, and then fill the tank to start the trip? Would doing this lead to a greater probability that the guess gauge was... well, you know... kinda, sorta, pretty-much accurate? ************************************************** ************** Just for the fun of it, here follows information on resetting the inclination sensors: First, some information from the Toyota Tech Manual: -------------------------------------------------------------------------------- "The direct acting fuel gauge is located in the sub tank. This gauge consists of a pipe surrounded by a coil. A float in the pipe moves up and down with changes in the fuel level. A magnet is attached to the float. The up and down movement of the float causes a change in the magnetic field. The flow of current through the coil creates a potential difference and the resultant voltage is transmitted to the meter ECU. "There are two inclination sensors located in the meter ECU to detect vehicle longitudinal and latitudinal inclinations and to correct the fuel level calculation. Corrections are made by the signals from the inclination sensors and the ambient temperature sensor located in the fuel tank. "The inclinometer must be reset if the customer complains that they can only pump a few gallons of gas into their tank or that they run out of gas with three or four bars left on the fuel meter. The inclinometer must also be reset if the Prius is refilled on an excessive slope or if the fuel gauge becomes inaccurate. Please refer to the Prius Repair Manual for the inclinometer calibration procedure. " [Emphasis added] ----------------------------------------------------------------------------------- And second, info on the procedure itself that was posted somewhile back: ----------------------------------------------------------------------------------- Bear68 Senior Member ... Anybody wanna reset the fuel gauge inclination sensor? Make sure your fuel level is somewhere between 1/4 and 3/4, and temp should be about 70-90 F. Step 1: PARK ON A LEVEL SURFACE!!!! If you are on a slope you will reset the sensor to an incorrect level!! Step 2: Press the ODO/trip button to turn the odometer to trip A Step 3: Turn off the ignition and set the parking brake. Step 4: DO NOT STEP ON THE BRAKE PEDAL! AT ALL! IT ISN"T NEEDED FOR THIS PROCEDURE!! Step 5: Press and hold the ODO/trip button and press the Power button twice. Step 6: Release and press the ODO/trip button three times Release-Press-Release-Press-Release-Press and HOLD. The Odometer on the combo meter should now be showing the normal mileage, as you hold the ODO/trip button down, the reading should change. Something along the lines of 650D0 or similar. The actual figures don't really matter. Step 7: Release and press the ODO/trip botton once more and HOLD it in. The figure will change again. This time, only ONE digit will change. 650D0>65010 as an example. Don't be afraid to try it. Even if it doesn't work, you won't goof anything up. Try, try again. It sometimes takes a half dozen attempts before you get it work right the first couple of times you do it. This only needs to be done once in a while. I would recommend once every ten tanks or so. I usually only do it when a customer has a fuel gauge issue. [Emphasis added.] Takes a bit of practice but it resets the ECU to try to be more accurate in it's estimation of your actual fuel level. GOOD LUCK!! ----------------------------------------------------------------------------------- Last edited by Rokeby; 06-02-2008 at 02:52 PM. |
| accuracy, elusive, fuel, gauge, perspectives |
| Fuel Gauge/Fuel Filler Pipe | galaxee | Toyota Prius Service Bulletins - TSBs | 7 | 04-04-2006 09:59 AM |
| Fuel Gauge | Harper | Gen II Prius Main Forum | 76 | 11-22-2005 12:50 PM |
| Fuel gauge way off | JackDodge | Gen II Prius Care, Maintenance and Troubleshooting | 26 | 11-07-2005 02:57 PM |
| Fickle Fuel Gauge or Shrinking Fuel Tank? | goldenpanda | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 04-05-2005 03:44 PM |
| My fuel gauge has gone mad | V8Cobrakid | Gen II Prius Main Forum | 9 | 09-23-2004 07:40 PM |
