| This is a discussion on I Beat the EPA--Post 'em here within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by pdoege Here is my first attempt. Pretty mediocre. In my defense the car was full of SCUBA ... |
| | LinkBack (20) | Thread Tools |
| | #481 | |
| A young senior member Join Date: Mar 2006 Location: Chicagoland, IL USA, Earth
My Car: 2006 Prius Model: Package: #1 Thanks: 12
Friends: 3 | Quote:
I just got back from a road trip, 1400 miles, I got 54.6 mpg computed, 57 on MFD. Either one is better than the EPA of 51 highway for my 2006. Beating the new EPA estimate is easy enough, I average 49.3 mpg lifetime on the car (24K miles). For my road trip, kept it below 70 mph (usually about 66-68) on the interstate, tires at 42/40, light winds. Had my scanguage hooked up, only used it to remind me not to push the accelerator too hard (kept the IGN at or below 20). Used cruise control only on the very level stretches. Light A/C usage was needed for most of the long drives. Also some moderate truck drafting (about 1-2 seconds back) for a few stretches, maybe 10-15% of the drive.
__________________ "We must be the change we seek" - Gandhi Last edited by nerfer; 08-03-2008 at 10:07 PM. | |
| | #482 | |
| Junior Member Join Date: Jul 2008 Location: Orlando, FL
My Car: 2008 Prius Model: Package: #3 Thanks: 0
I used the cruise control for the 1st half of the trip. It seems to be easily confused, and will stay in very low MPG throttle settings for no apparent reason. On the way back I used manual throttle control. I wish I had a SG. Many times I would be getting 40mpg-ish and backing off the throttle just a hair would create 50-60 mpg. I wish I knew what I was actually doing! I also tried drafting big trucks at a 2 second distance. I could gain about 10% or so from the draft. The scuba bottles are very close to the rear wheels, and this caused a very obvious nose up attitude for the car. I think that if I had rebalanced the bottles I would have gained a few %. There were a few times were I was able to stay in the "WS" and Stealth modes for quite a bit of time. It is quite fun to min/max fuel usage. I've ordered a SGII so I should be able to see exactly what is giving those mysterious MPH boosts when it gets in. Regards, Peter | |
| | #483 |
| Senior Member Join Date: May 2008 Location: SE PA
Friends: 0 | I can't recall whether I posted here before, but I got 55 mpg driving up to the mountains and 60 mpg on return, more downhill --150 miles each way, about 2/3 highway. Tire pressures were set about 6 weeks ago to 38/36. Don't know what they are now. I follow speed limits, 55-65 mph. Sparing use of the AC--maybe once or twice on return. MPG measured electronically. Don't trust the calculated mpg because of the gas tank bladder. Around town, I get about 48 mpg with lots of short trips and cold starts. With longer trips around town and fewer cold starts, I get around 52 mpg. This is basically summer driving. Last edited by PriusSport; 08-03-2008 at 11:42 PM. |
| | #484 | |
Friends: 3 | Quote:
The first part of the drive might've had the A/C on max, which means the engine would work harder, then it drops down a bit (maybe switches to interior air recirculation), that could help you and the engine can cut out easier. I wouldn't blame CC right away, unless it's hilly in your part of Florida (?? does Florida have hills?). Up here in the winter, it takes several miles to warm up the engine, but somehow I doubt that was your scenario. Backing off the throttle does increase the mpg, but unless you have a slight downhill, you will probably slowly lose speed. (Like the pulse-and-glide technique when driving under 40 mph). Scangauge will show when the engine is truly off (0% LOD) and the engine coolant temperature (engine won't turn off until FWC is over 150'F or thereabouts (forget the exact number, it tends to stay around 182'-186'F once warmed up). Last edited by nerfer; 08-03-2008 at 11:47 PM. | |
| | #485 | |
| Junior Member Join Date: Jul 2008 Location: torrance, ca
My Car: 2004 Prius Model: Package: #5 Thanks: 0
| | #486 |
| Junior Member Join Date: May 2008 Location: Yardville, New Jersey
Friends: 0 | I purchased my '08 Package 6 Super White this May and went on a trip last week from Central New Jersey to Leicester Vermont (320 miles one way). At the start of my trip, I had approximately 2,700 miles on the odometer. The trip started on the NJ Turnpike, to the Garden State Parkway through New York ... etc. Most of the time I was traveling between 65 and 70 MPH. As we approached New York it was all up hill/down hill and winding road driving. As we reached Vermont the roads were steep but the rewards going downhill were ... well ... rewarding :-) I had my two sons with me and a large 50 lb suitcase in the back and other items to take with us (approx 550+ lbs altogether). I didn't pay attention much to the fuel usage on the MFD like I normally do when driving around my town. I had the GPS on most of the time. I had the cruise control ON most of the time and did not use the air conditioning on the way up ... and I got 52+ MPG. On the way home ... again, I had the cruise control ON and had the same weight BUT this time I DID use the air conditioning and was going between 65 and 72 mpg ... and got 54+ MPG. My tires were inflated 42 front & 40 rear. I've been averaging between 52 and 54 MPG at home around town (I got 52 mpg while in VT). I once achieved 59 MPG when trying my best to conserve using the MFD. I travel 10 miles to work and back (traveling 30 - 40 mph) with 12 + stop lights along the way and I'm getting 52 MPG. I watch the MFD and know how to feather the gas pedal etc. I expect I'll be getting in the 40's in the winter however based on what I've read here. I couldn't be more pleased!!!! I just love the car! Hope this helps! Last edited by Gutsy; 08-06-2008 at 11:57 AM. |
| | #487 |
| Junior Member Join Date: May 2008 Location: Cabin John, Md.
My Car: 2008 Prius Model: N/A Package: #5 Thanks: 1
Friends: 0 | The MFD said about 57 mpg for most of the second tank, but my calculator says 66.4 mpg for the second tank. Most of these miles have been highway at about 55 to 60 mph. I am running the tires at 40/38, and use the scan gauge to try to keep the RPMs below 2200 (per the hobbit). Don't need much A/C, as the car is parked in a garage at work. I guess the mpg will improve as the tires and engine break in. Last edited by rokibler; 08-09-2008 at 04:33 PM. |
| | #488 |
| EPA MPG #'s killer Join Date: May 2007 Location: Elkhart, IN
Friends: 6 | |
| | #489 |
| Canonus Curiosus Join Date: Aug 2007 Location: Chicagoland (West)
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 150
Friends: 18 | Diamondlarry, Is that all you've got!? WOW!! Congrats!! Where do you plug it in? |
| | #490 | |
Friends: 6 | Quote:
The only plug is on th block heater, so far. I would love to get my hands on a PHEV for a few weeks or more. I hear there is doing to be one at the MiHG meeting in Oak Creek, WI next Saturday but I have to work. | |
| beat, epapost |
