| This is a discussion on I Beat the EPA--Post 'em here within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by 9G-man Not flat where I am, and that's an advantage. I exploit the downhills by gliding. gotta ... |
| | LinkBack (20) | Thread Tools |
| | #511 |
| Senior Member Join Date: May 2008 Location: Philadelphia
My Car: 2010 Prius Model: IV Package: No Package Thanks: 3
Friends: 0 | I know how to P&G, but I'm usually driving on inclines on the way to work so it's tough to sustain a glide. And when I talk about inclines, I mean incredibly steep and unavoidable. On the way home, I get about 60mpg. |
| | #512 |
| New Magnetic Gray Prius owner Join Date: May 2008 Location: Middlesex County, MA
My Car: 2008 Prius Model: Package: #3 Thanks: 2
Friends: 0 | I just got 64.3 mpg traveling 35-40 mph and hilly back roads up in N.H.!!! Dbcassidy |
| | #513 |
Friends: 0 | |
| | #514 |
| EPA MPG #'s killer Join Date: May 2007 Location: Elkhart, IN
Friends: 6 | No, it didn't. But then again, it usually never does agree with the hand calcs. I have topped off for the entire 23K+ miles of the car and the MFD is usually one way or the other(high or low)compared to hand calcs. This last time I think it read 97.1 or 97.2. |
| | #515 | |
| Member Join Date: Sep 2008 Location: Central NC
My Car: 2008 Prius Model: Package: Base Thanks: 0
Friends: 2 | Quote:
| | #516 |
Friends: 6 | |
| | #517 |
Friends: 2 | Much better! I am curious -- do you have a plug-in conversion to obtain 100 mpg? I barely reach half that (though I'm a new Prius owner). My best is 54.42 calculated/56.2 computer on fill-up, with higher short-term averages. I would be glad just to reach the 55-60 mpg range that some have reported. But ... I wonder if landscape has something to do with max mpgs as well as the ability to drive the Prius optimally. We seem to have a lot of long inclines that reduce our mpg's here (even though I tend to back off the gas and not use the cruise on those inclines). EDITED 10/4/2008 w/higher mileage. Last edited by NC_Prius; 10-04-2008 at 02:26 PM. |
| | #518 | |
Friends: 6 | Quote:
I have done some figuring and have come to the conclusion that I would never need to use gas for my work commute and for most of my errands. My work commute is, for the most part, a straight line that runs east to west. There is only a 3-5' net elevation difference between work and home but there are several significant hills in the middle. The route is 11.0 miles long and, on several occasions, I have hit 100+mpg within 3.8 miles of leaving home. In those cases I can usually hold it the rest of the way to work.Landscape has a lot to do with it. There are some routes I chose based on whether I'm going somewhere or coming from somewhere. For instance, there could be a hill real close to a stop sign. If the route was such that the hill came just before the stop, I can use that to help slow the car to the stop. If, on the other hand the stop was just after the stop, this would mean accelerating from a dead stop uphill. There are some errands where I can tweak the route to make the terrain work out better. As for driving the Prius optimally, that helps but it also has a lot to do with when I commute/run errands. For most of that record tank, I was going to work at 5:00-5:30am and returning home 12-14 hours later. This helped to avoid the vast majority of traffic so I could P&G to my heart's content. I also use an EBH in the mornings all year long. I put it on a timer for 3-5 hours before I leave. I'm going to talk to my new boss about the possibility of plugging in at work if I pay him for the juice. The car is also garaged at home so I don't have to use the defroster to clear off the windows.
__________________ ![]() Best tank: 101.1 mpg over 867.4 miles from 8/9/08-9/6/08 Longest tank: 1184.2 miles from 6/15/09-7/13/09 "Fear exists for one purpose: to be conqured!"-Catherine Janeway Last edited by diamondlarry; 09-14-2008 at 07:22 AM. | |
| | #519 | |
Friends: 2 | Quote:
That's great. Well, good job getting it that high. I know it's possible because coming home through an adjacent subdivision I'm consistently able to hit nearly 100 mpg average. But the rest of my commute or runs for errands aren't so cooperative. So -- I'll be happy if I ever reach the 60mpg mark. | |
| | #520 |
Friends: 0 | So, I checked my tire pressure and the rears are 32 PSI! I didn't have time to check the front but they can't be much different. I guess if I'm hitting 52mpg now it should be somewhat better with proper pressure. |
| beat, epapost |
On 9/16/08 I filled up with 8.58 gallons after traveling 867.4 miles for 101.096 mpg.
