This is a discussion on I Beat the EPA--Post 'em here within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Thought I would throw my numbers in I filled my Prius up this Sunday and for my first 46 miles ...
LinkBack (20) Thread Tools
Old 04-06-2009, 03:50 PM   #551
kirkrv8
kirkrv8's Avatar
Package: #8
Default Re: I Beat the EPA--Post 'em here
Thought I would throw my numbers in I filled my Prius up this Sunday and for my first 46 miles I have averaged 66 mpg Normal in the summer is 55 mpg, winter it drops to 48-50 mpg.
I drive conservatively
kirkrv8 is offline
Old 04-06-2009, 08:02 PM   #552
JimboK
One owner, low mileage
JimboK's Avatar
Friends: 6
Originally Posted by Politburo View Post
I'm a bit confused. You first say there is no difference, and then say that the difference is 2.3%. Do you mean that the average single-tank difference is 2.3%, and there is no difference in the lifetime numbers?
I didn't say there is no difference. I was responding to the question, "Why is there such a difference...?" The question's implication was that there is a sizable difference between displayed fuel mileage and actual use, which there is not. After tracking data for a year and half now, I am confident that in my car the display is different from actual use by a little over 2% (actually 2.15% after the latest fillups). It is impressive to me how small the difference is and how accurately the car is able to compute it for the display.
See this thread for more, including a copy of my spreadsheet. If you have any further questions, you might consider posting there instead of here, since we're straying off topic a bit.
Jim
Click here for car details.
JimboK is offline
Old 04-07-2009, 11:08 PM   #553
abra
Originally Posted by 2009Prius View Post
How often do you check your tire pressure? Thanks!
every tank
btw
i hate new tires
abra is offline
The Following User Says Thank You to abra For This Useful Post:
2009Prius (04-08-2009)
Old 04-15-2009, 11:56 AM   #554
2009Prius
2009Prius's Avatar
Friends: 19
Smile Re: I Beat the EPA--Post 'em here
Just reached 50MPG life time average at 700 miles yesterday.
2009Prius is offline
Old 04-16-2009, 08:46 PM   #555
rokibler
So I have gotten about 55 mpg over the life of the car so far, and with the warmer weather, that average should go up.
Last edited by rokibler; 04-18-2009 at 09:12 PM. Reason: Trying to include a picture
rokibler is offline
Old 04-19-2009, 09:38 AM   #556
KAR IDEA
Fuzzy Westchester NY Moderator
KAR IDEA's Avatar
Package: #3 Touring
Friends: 13
mpg 50.9 total tank miles 434 gallons at fill up 8.5 avg temp 50 avg ride time 45 mins
...on April 15th.
KAR IDEA is offline
Old 04-19-2009, 09:43 AM   #557
ETP
Ancient and decrepit
ETP's Avatar
Friends: 57
...on April 15th.
It will interesting on how my new Prius compares to my 2007 Civic Hybrid. I was getting 49-54 MPG until I changed the tires and they spiked the gas with ethynol. Now It get 45-47 ARGH!
Boy this Prius is sure different in a good way.
I noticed the steering wheel is angled to the left about 5 degrees.
ETP is offline
Old 04-28-2009, 11:23 AM   #558
Matt Herring
Matt Herring's Avatar
Friends: 9
I just bought a 2009 Base Prius about a month ago and have filled up once with an actual fill mpg of 56.5 for my first tank of 511 miles.
I drove the Prius for 150 miles to get some road under my belt before adding mods to the car to increase mpg. Prior to my first official fill I added a full upper grill block and one slot of the lower grill block. Tires are also at 44 psi front and 42 psi rear.
Following my first official tank I added a grill block to slot 2 and 3 in the lower grill block. After 275 miles I'm currently at 60.4 in-dash mpg and 57.4 Scanguage II mpg. So...I'm somewhere in the 58-59 mpg actual fill range right now. With warmer temps I should be close to or over 60 mpg soon! (Note: my max temp on the SGII has not peaked past 200 degrees since adding the grill block despite temps being 75, 82 and 90 in three of the last four days...constant monitoring in use).
My best 11 mile commute to work was 73.3 mpg on my SGII (roughly 75 mpg actual).
Additional planned mods are: Rear wiper delete, reduced antenna, wheel discs, passenger side mirror relocation). I'm a frequent user of ecomodder.com if you are looking for additional ways to improve your own mpg!
Glad to be a part of this forum and look forward to some good info. from this site!
Matt Herring is offline
Old 05-01-2009, 01:51 PM   #559
ejmckee
So far on this tank I am doing better than usual. Temps in the 50's to 60's, hilly highway drive 22 miles each way. I normally get about 50.5 mpg on a tank down to 1 or 2 pips. I just refueled at a Shell station which advertises nitrogen enriched gas, but also had a sticker on the pump that says gas may contain ethanol. That being said for a potentially 10% ethanol fuel I am doing 57.3 mpg over 100 miles, my best average so far, and the car has about 1650 on the ODO.
I get psyched for 50 mpg, and hopefully I can maintain above 55mpg and someday I will hope to see 60+ mpg, although with the hills and the flow of traffic I find myself pushing the car to keep it around 65mph.
ejmckee is offline
Old 05-03-2009, 11:08 PM   #560
spitinuri
spitinuri's Avatar
I just had my second oil change with Mobil1 0W-20 and recently go 63 mpg @ 59 mph over a 35 mile trip. My last 400 miles was mostly highway 70 mph and got 50.9 mpg. Goodyear Integrity's 52/50 psi.
spitinuri is offline
beat, epapost
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-fuel-economy/1429-i-beat-epa-post-em-here.html
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 02-24-2009 06:27 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 02-07-2009 10:13 AM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 01-19-2009 08:06 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 11-18-2008 08:24 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 10-29-2008 10:35 AM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 10-29-2008 09:28 AM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 10-16-2008 10:44 AM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 09-12-2008 12:33 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 09-09-2008 11:01 AM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 07-18-2008 08:34 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 07-16-2008 06:46 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 07-11-2008 07:45 AM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 07-10-2008 10:37 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 07-10-2008 09:13 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 07-10-2008 03:22 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 07-10-2008 11:54 AM
New Mercedes equals Grieve - Page 3 - Bike Forums This thread Refback 04-25-2008 10:53 AM
Ford Taurus .net Angel May Be On To A Trend (a.k.a. Webmaster bought a Prius) This thread Refback 04-22-2008 11:25 PM
New Mercedes equals Grieve - Page 3 - Bike Forums This thread Refback 04-22-2008 07:03 PM
New Mercedes equals Grieve - Page 3 - Bike Forums This thread Refback 04-22-2008 07:00 PM
