| This is a discussion on Most efficient speed for best MPG? within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Last summer, there was a lot of road construction on the highway that runs north of the Trans Canada to ... |
| | #11 |
Friends: 12 | Last summer, there was a lot of road construction on the highway that runs north of the Trans Canada to my hobby farm. A lot of 70 km/h speed limits. With the car at 70 km/h - about 42 MPH - the MFD claims a consistent 3.7 l/100km: 76 MPG Imperial gallon |
| | #12 | |
Someone else has already asked. Nonehtless are you referring the MPG shown on the display while driving or the MPG derived by dividing total miles by number of gallons used? Since the original inquiry referred to effciency which is most commonly an outcome variable rather than a process variable, the changing MPG is not a good measure of efficency. Others have already pointed out that gliding displays 99 MPG but that has little or nothing to do with actual number of gallons of fuel consumed. | |
| | #13 | |
So it includes my trip, usually to work via back routes that are quite repeatable. 15 miles or so total. I never measure going home, because traffic then is just too variable. Instant readouts of 80 plus are easy to get and mean nothing, as does the 99 when on battery. But battery use pays well when you are on gas only 1/2 or less of the time and are still getting 50 or better. I go by the total result. And now that I have my code upgrade I am on battery even more, and my mpg has gone up noticably as a result, except in the cold weather where the engine just has to run full time anyway to keep warm. For mpg 30 mpg is better than 40 due to air drag alone. And under 40 you will be on battery anyway if your car is working right. Only way to avoid it is in the country with pulse and glide but not practical around where I am. I am quite happy running on battery trying for 75 mpg or better instead of pulse and gliding and trying not to charge the battery to get 100 mpg with my speed varying all over the place. | |
| | #14 |
Friends: 14 | I have a copy of the US gallons/oF page from the spreadsheet, but could not find the entire spreadsheet, to give due credit to the author. Wayne Brown's program (HSD version) was used. I will try to atatch the image here. |
| | #15 | |
Friends: 4 | Quote:
Yea.. between those speeds you can utilize the "pulse and glide" technique that has shown to get up to 110mph? http://hybridcars.about.com/od/owner...seandglide.htm Of course thats not too practicle for driving on the freeway! | |
| | #16 |
Friends: 0 | Seconded. Read up on what the Pittsburgh Marathoners did. It is nowhere near as simple as a sweet-spot speed -- you have to take into account what modes the system is running in. The idea with P&G is that you're running the engine efficiently, or not at all, and NOT cranking a lot of energy in and out of the battery but using your momentum to best advantage. For most people, above 41 mph and most bets are off WRT efficient engine use, unless you know how to use "warp stealth" that allows the engine to turn but not burn gas. . Wayne's site is http://privatenrg.com -- recommended reading indeed. . _H* |
| | #17 | |
| Senior Member Join Date: May 2004 Location: Singapore
My Car: 2003 Prius Model: Package: Base Thanks: 1
Friends: 1 | Quote:
| | #18 | |
Is it me, or does it seem odd to you, too, that you would get any reading below max (99.9) when you are using "battery only"... | |
| | #19 | |
| | #20 | |
That management includes all the little weirdnesses like stopping the ICE when it's not required, regenerating electricity from the car's kinetic energy (something a gas-only vehicle cannot do ever), and balancing the use of electricity and gasoline. ALL the energy used by the car comes from gasoline. The battery is just a big (not big enough, in my opinion) energy buffer. Technically, you are correct, but it's like saying that the hammer is what makes a house.
__________________ 2006 Seaside Pearl Package #7 (NL) Coastal EV mod Removed "Playschool" rings Become a Plug-In Partner "That the automobile has practically reached the limit of its development is suggested by the fact that during the past year no improvements of a radical nature have been introduced." Scientific American, Jan. 2 edition, 1909. | |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-fuel-economy/14675-most-efficient-speed-best-mpg.html | ||||
| Mercury Mariner Mpg, New Mercury Mariner Hybrid For Sale White, Mariner Outboard Motor Pictures - Cowhidemirror | This thread | Refback | 03-09-2009 06:13 AM | |
| Understand the MPG meter (one more time) - GreenHybrid - Hybrid Cars | This thread | Refback | 05-17-2008 12:28 AM | |
| Comments on the FAQ - Page 2 - GreenHybrid - Hybrid Cars | This thread | Refback | 02-01-2008 07:33 AM | |
| EPA - Cars LESS Fuel Efficient Than In The 80s! | Areometer | Gen II Prius Fuel Economy | 17 | 07-04-2008 12:17 PM |
| Energy-efficient californians | chogan | Environmental Discussion | 8 | 02-27-2007 04:54 PM |
| Efficient speakers | Jmad1138 | Gen II Prius Audio and Electronics | 10 | 12-09-2006 01:19 PM |
| Prius less efficient at highway speed than two-mode hybrids? | sola | Gen II Prius Technical Discussion | 11 | 06-15-2006 10:20 PM |
| Prius 1/3 as efficient... | texassalsa04 | Gen II Prius Main Forum | 5 | 01-10-2006 12:38 PM |
