| This is a discussion on Most efficient speed for best MPG? within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; <div class='quotetop'>QUOTE(ken1784 @ Mar 24 2007, 07:41 AM) [snapback]411445[/snapback]</div> I believe the marathon was done using Pulse&Glide, a lot of ... |
| | #51 | |
My Car: 2010 Prius Model: III Package: #1 Thanks: 138
Friends: 19 | <div class='quotetop'>QUOTE(ken1784 @ Mar 24 2007, 07:41 AM) [snapback]411445[/snapback]</div> Quote:
Changing the velocity over any given route will always require more energy than maintaining a steady state speed. The non-linear aerodynamic effects at speeds above the steady state speed increase the drag, power and energy requirement much faster than the reduction in drag, power and energy at a speeds below the steady state. Using calculus, we can calculate the power and the energy required to move any given distance and this is where I have to dust-off my college texts to 'do the math.' (NOTE: I remember having to do this calculation in one of my engineering classes, thermodynamics I think.) The "pulse" part works for ordinary cars because traditional gas engines are terribly inefficient at partial throttle settings (See Figure 15, "Development of New-Generation Hybrid System THS II - Drastic Improvement of Power Performance and Fuel Economy", K Muta, M. Yamazaki, J. Tokieda, SAE 2004-01-0064.) By putting an ordinary ICE into a higher power mode, it will generate power at a more efficient specific fuel consumption than partial throttle but the excess of power causes the vehicle to accelerate. The "pulse" is a by-product of trying to operate a traditional ICE at high power settings but our Prius is different. "Pulse and glide" is critical to Honda and gas-only vehicle mileage but the Prius has not only an unusually flat, specific fuel consumption but also the ability to auto-start/stop the ICE. If the Prius ICE is kept within the 1,600-2,600 rpm range (based on current data,) it will be in the most efficient power mode. But there is an energy loss associated with starting and stopping the ICE and this is an area under investigation. To properly model Prius efficiency, the ICE start and stop energy has to be part of the model. There may be a Prius "Pulse and Glide" profile that delivers better performance than a steady state speed. If so, it is likely to come from using the battery to extend the glide and optimum acceleration in the high-efficiency speed range as a way to minimize ICE start/stop energy loss. But the battery recharge has to happen during the ICE operation time and if done badly, it won't be recharged enough to sustain the next glide. Also, the minimum speed needs to be balanced against the 'overhead' power requirement. But this performance model with real data doesn't exist in an open source, yet. I'm sorry if this seems long and somewhat confusing. I didn't take enough time to write it shorter. But as I refine my data and models, eventually, I'll share AND THEN TEST the results. Bob Wilson | |
| | #52 |
Friends: 8 | Hi Bob, It is hard to understand your post what's the point is. Agin, the 1400 mile marathon was based on Pule&Glide, pulse up to about 40 mph the glide down to 30 mph. I believe the bast shift (#10) by Wayne Gerdes was slower than that, pulse up to 35 mph and glide down to 20 mph, average 24.3 mph. The FE on pulse part was 9.84 km/L (23.1 mpg) and engine on % distance was 19%, so the rest 81% is just gliding from 35 mph to 20 mph. I still believe we can't compare the 1400 mile marathon data to Wayne's constant speed graph. Ken@Japan |
| | #53 | |
Friends: 19 | <div class='quotetop'>QUOTE(ken1784 @ Mar 25 2007, 02:56 AM) [snapback]411820[/snapback]</div> Quote:
I'll see if I can't get the math model worked out this week but I'll have to review some of my old engineering texts (if I still have them.) If I don't have much luck, excel can model a successive series of approximations. But for now, I would suggest looking at the MPG vs MPH plot with the marathon data (you may need to refresh the browser to get the latest copy ![]() The NHW20 Prius marathon used high pressure, well-worn tires, a more efficient transaxle, warmer than standard temperatures, a lower coefficient of drag and more efficient transaxle system. Still the Prius endurance test is within engineering measurement error of the NHW11 theoretical line. Furthermore, the slope of the Prius endurance data points suggests a curve that has a higher peak MPG value that Wayne has nailed that at 20 mph, backed up by testing. The speed log for the Insight test shows an average of 18 mph and over the last days, closer to 15 mph. Now an Insight's IMA system would respond especially well to any pulse and glide protocol that uses ICE off, neutral" for the glide. But the Prius systems are different with a built-in, automatic cycling between ICE-on and ICE-off operation at speeds below 42 mph. It is possible that the energy lost in starting and stopping the Prius ICE is significant at the peak MPG, constant speed. It is possible that acceleration at an ICE speed between 1,600-1,900 rpm followed by a glide that ends at a speed that permits recharge on the subsequent 'pulse' may be the most efficient protocol. ![]() Understand that I prefer to start with a good model, followed by data and testing to answer this question and develop a reproducible protocol for Prius marathon driving. The ultimate answer is an automated Prius that drives the marathon under computer control with a mannequin or crash-dummy for the driver. Bob Wilson | |
| | #54 |
| Junior Member Join Date: May 2008
Friends: 0 | No matter what, if you're going to fast you're going to get horrible gas mileage. There's calculator at MpgForSpeed.com - Fuel Efficiency Vs. Speed that shows you the effects of your speed on your mileage. |
| | #55 |
| Junior Member Join Date: May 2008 Location: SoCal The "OC"
Friends: 0 | Can we bring this back in to the real world where people have to drive at least the speed limit....and don't have an excel spreadsheet and DNA analyzer always with them? If I'm taking a 250 mile road trip that will be 80% high way...driving the speed limit will produce better mpg than driving 15mph higher. THERE! Solved. |
| | #56 | |
My Car: 2007 Prius Model: Package: #6 Thanks: 1
Then, if you get off the Interstate onto the country roads, and get yourself behind an International Harvester chugging along, you might be lucky enough to exceed 100 mpg. You can certainly improve your mpg by driving these non-Interstate roads and keeping your speed below 45 MPH. It all depends on how much of a hurry you are in to get to your destination. | |
| | #57 | ||
| | #58 | |
| Senior Member Join Date: Apr 2008 Location: Boynton Beach, FL, USA
Friends: 1 | Quote:
![]() And think about how much road rage that would instill in other drivers... I'll stick close to the posted limit, just for safety's sake. Bob | |
| | #59 | |
| Senior Member Join Date: May 2008 Location: Navarre, Florida
My Car: 2008 Prius Model: Package: #2 Thanks: 4
That said, can there be real-world test reports based on actual use, speed, P&G, on normally traveled roads -- nothing too high-falutin', just "we drove this fast at this temperature with a head wind on this terrain for this many miles and got this MPG", all without inciting road rage or keeping us from getting where we want to go expeditiously. Multiple tests should give a good idea of what we can expect day-to-day. Perhaps moderators can set up a forum for that? I'm willing to contribute results of our first trip, some 460 miles after we pick up Black No. 2 in a couple of weeks. | |
| | #60 | |||
Friends: 19 | Quote:
Bob Wilson Last edited by bwilson4web; 05-25-2008 at 07:38 PM. | |||
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-fuel-economy/14675-most-efficient-speed-best-mpg.html | ||||
| Mercury Mariner Mpg, New Mercury Mariner Hybrid For Sale White, Mariner Outboard Motor Pictures - Cowhidemirror | This thread | Refback | 03-09-2009 06:13 AM | |
| Understand the MPG meter (one more time) - GreenHybrid - Hybrid Cars | This thread | Refback | 05-17-2008 12:28 AM | |
| Comments on the FAQ - Page 2 - GreenHybrid - Hybrid Cars | This thread | Refback | 02-01-2008 07:33 AM | |
| EPA - Cars LESS Fuel Efficient Than In The 80s! | Areometer | Gen II Prius Fuel Economy | 17 | 07-04-2008 12:17 PM |
| Energy-efficient californians | chogan | Environmental Discussion | 8 | 02-27-2007 04:54 PM |
| Efficient speakers | Jmad1138 | Gen II Prius Audio and Electronics | 10 | 12-09-2006 01:19 PM |
| Prius less efficient at highway speed than two-mode hybrids? | sola | Gen II Prius Technical Discussion | 11 | 06-15-2006 10:20 PM |
| Prius 1/3 as efficient... | texassalsa04 | Gen II Prius Main Forum | 5 | 01-10-2006 12:38 PM |
