| This is a discussion on Most efficient speed for best MPG? within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by fthorn Got to try out the 30 mph on the highway fuel economy today. Storm had everyone ... |
| | #71 |
My Car: 2007 Prius Model: Package: #6 Thanks: 1
Friends: 0 | I suspect that the rain and winds had more to do with your poor mileage than your speed. Not reaching S4 might have contributed a bit, but probably not as much as the weather. Did the traffic conditions require you to use the brake much? If so that probably ate into your fuel economy as well. |
| | #72 | |
Friends: 20 | Quote:
Bob Wilson | |
| | #73 |
| Senior Member Join Date: Apr 2008 Location: Boynton Beach, FL, USA
Friends: 1 | I think I am going to have to re-read this whole thread as well as some other sources several times. I may need to summarize things to get it all straight in my head. Especially the S3, S4 thing. I have a flat, straight stretch of city road that frequently has little or no traffic. It's about 3/4 mile long from light to light. almost two if the light is green when I get there. I have tried speeds, with CC, of 30, 35, 40, 45, and 50 (50 is over the limit). I regularly get the best MPG at 45 - 50 MPH. It always seemed a little strange but hey, the car is smarter than me. Often it goes into EV for a variety of reasons and of course that throws everything off as I am trying to get results with the ICE running. Time for study, Bob
Mods: Reverse Beep, Window Tint, Wheel Rings gone, Unlock all Doors, Dash Topper, Window Guards ordered, more to come |
| | #74 | |
If you force the ICE to idle while you drive slower and slower, then obviously your fuel economy will suffer more at the slower speeds. The ICE continues to burn through the same amount of fuel per minute while idling, and the vehicle covers an ever shorter distance per minute. Divide shorter distance by same fuel and you get a reduced MPG. Now if you shut the ICE off while traveling some distance you have the opposite effect. You are increasing the distance covered while burning no additional fuel at all. Therefore MPG increases. What are you trying to calculate? The amount of fuel burned per minute while the engine idles? | |
| | #75 | |
Friends: 1 | Quote:
In the Prius, I would expect the ICE to run at an optimum RPM. If this is true then at very slow speeds I would expect the ICE to send less energy to the wheels thus lower MPG. I don't think slower always translates to higher MPG. Thus slow-slower does not always increase MPG. I would expect there to be a "sweet spot", below which you reach the point of diminishing returns. The great thing about the Prius is that it minimizes the problem by using stored energy from the battery to keep the MPG high. Bob | |
| | #76 |
| Junior Member Join Date: Mar 2008 Location: Charleston, SC
Friends: 0 | 43-47 mph seems to be the best for me. I regularly see the MPG (when on CC) at 50-70 MPG. |
| | #77 | |
Friends: 8 | Quote:
I think your explanation is perfect. Anyway, there is a thread regarding to the stages. Prius Stages of Operation & Operating Mode Availability -A Reference Aid Ken@Japan | |
| | #78 | |
As such, every vehicle suffers poor MPG at VERY low speeds because this base energy use is larger than the energy use to move the vehicle. As the vehicle increases in speed, it eventually crosses a threshold where the energy to keep it operating is less than the energy to overcome rolling friction and air resistance and other additional energy drains of a moving vehicle. Because the Prius can shut the ICE off, it reaches this threshold at lower speeds than other vehicles. Through testing, some of the PriusChat regulars have found this speed for the Prius to be somewhere around 20 MPH. In other words, 20MPH will get you the best possible MPG in a Prius. As you get further away from 20 MPH in either direction (faster or slower) your MPG drops. So, for the Prius, slower increases MPG until about 20 MPH. On other vehicles the speed at which MPG peaks is higher than the Prius, because the fuel used to keep the ICE idling needs to be compensated for with some reasonable distance covered. This number is probably specific to each individual vehicle, but I'd expect it to be more than 20 MPH and less than 45 MPH for most vehicles. So on expressways, slower will almost always mean better MPG, but on roads where the speed limit is closer to 45 MPH faster might mean better MPG in some vehicles. Which it does. Of course it eventually reaches a point where the optimum RPM is 0 since even idleing it generates more energy than the wheels need. Actually a more accurate description might be that the optimum RPM is less than the idle RPM. Since the vehicle can't run the ICE at half the RPM, it instead runs it at full RPM but cycles it on and off so that it is only running half the time. The excess energy generated while the ICE is on is buffered up in the battery and fed back to the wheels while the ICE is off to keep the vehicle moving smoothly. Last edited by Danny Hamilton; 06-05-2008 at 08:41 AM. | |
| | #79 | |
In the US the most fuel-efficient speed is 42 MPH. In Europe, Japan, and Australia it's 42 kph. :_> Last edited by richard schumacher; 06-05-2008 at 10:37 AM. | |
| | #80 | ||
Friends: 1 | Quote:
I did have another observation/question but I think I'll start a new thread regarding ICE vs battery at highway speeds. Thanks, Bob | ||
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-fuel-economy/14675-most-efficient-speed-best-mpg.html | ||||
| Mercury Mariner Mpg, New Mercury Mariner Hybrid For Sale White, Mariner Outboard Motor Pictures - Cowhidemirror | This thread | Refback | 03-09-2009 06:13 AM | |
| Understand the MPG meter (one more time) - GreenHybrid - Hybrid Cars | This thread | Refback | 05-17-2008 12:28 AM | |
| Comments on the FAQ - Page 2 - GreenHybrid - Hybrid Cars | This thread | Refback | 02-01-2008 07:33 AM | |
| EPA - Cars LESS Fuel Efficient Than In The 80s! | Areometer | Gen II Prius Fuel Economy | 17 | 07-04-2008 12:17 PM |
| Energy-efficient californians | chogan | Environmental Discussion | 8 | 02-27-2007 04:54 PM |
| Efficient speakers | Jmad1138 | Gen II Prius Audio and Electronics | 10 | 12-09-2006 01:19 PM |
| Prius less efficient at highway speed than two-mode hybrids? | sola | Gen II Prius Technical Discussion | 11 | 06-15-2006 10:20 PM |
| Prius 1/3 as efficient... | texassalsa04 | Gen II Prius Main Forum | 5 | 01-10-2006 12:38 PM |
