This is a discussion on New owner? Want MPG help? Read this first. within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by margo I even drove another prius under the same conditions with equal mileage and, guess what. . ...
LinkBack (26) Thread Tools
Old 01-01-2009, 03:35 PM   #161
Friends: 37
Default Re: New owner? Want MPG help? Read this first.
Originally Posted by margo View Post
I even drove another prius under the same conditions with equal mileage and, guess what. . . the other car reached over 43MPG.
Margo, that really doesn't mean much if anything. Unless you drove the two cars the same exact day, same exact speed, same exact starting temps for ICE and batteries, exact same tire pressures, exact same traffic conditions, etc. Esp. if the route is shorter than about 20 miles it's nearly impossible to claim any differences in MPG.
BTW, have you hit 'reset' on your MFD mpg readout? if not you're looking at a cumulative MPG since the car was first rolled out...so your more recent mpg may be a lot better but it'll take several tanks to reflect that.
Evan E. Fusco, MD
efusco is offline
Old 01-26-2009, 01:12 AM   #162
pepper04
I think I may have a similar situation as you in that I do a lot of short trips in the city, and I've been told the cold weather makes the mpg worse. I am now getting 20-25 mpg since the last few months and have been told by the Toyota dealership that this is normal for people who live in the city in cold places. Not sure what to make of it.
pepper04 is offline
Old 01-26-2009, 09:36 AM   #163
JimboK
One owner, low mileage
JimboK's Avatar
Friends: 6
Cold weather + short trips is indeed one of the worst-case scenarios for the Prius. That's an MPG killer for any car. But the effect is greater in the Prius because in conditions like yours the engine will never reach full operating temperature and, unlike a fully warmed engine, will never shut down when the vehicle is moving.
I strongly suggest you check out an engine block heater. That should at least get you into 30+ MPG territory. Do a good search for details; there are several good threads on the topic. PC member/Boston area resident Hobbit might be willing to assist with installation if you're mechanically challenged (like me).
Jim
Click here for car details.
JimboK is offline
Old 03-23-2009, 11:51 AM   #164
donalmilligan089
If i only drove the 5 or six miles at a time im sure milage sufers. I drive some leisure trips farther, and get better mpg. Forget the dataon screen, very inaccurate I use actual gal. and odometer reading at each fill up and avg, 41+ mph still better than even sub compact in other cars. Prius is bigger and more comfortable than small hondas or carollas Don
donalmilligan089 is offline
Old 03-23-2009, 01:05 PM   #165
Frayadjacent
Resident Conservative
Frayadjacent's Avatar
I'd concur with the sentiment that short trips and cold weather KILL fuel economy. I'm a newb here and have had my Prius for about 48 hours... but I had an Insight a few years ago, so I'm familiar with what can affect fuel economy.
Short trips are killer, because the engine won't get to temperature, where it is the most efficient, and in our cars, will shut off when it is not needed.
Batteries also do not perform well in cold weather and need time to warm up.
I found that in the Insight, the optimal minimum drive distance was ~12 miles. That gave it enough time to warm up and regenerate enough so that the battery could assist. I have not yet become familiar enough with the Prius to tell anyone what the optimal minimum drive cycle is, but I'd wager a 6 mile drive is not enough.
Now I live ~23 miles from the office, mostly highway, so I'm hoping the Prius will do well on my commute.
Wealth is the product of man's capacity to think.
Who is John Galt?
Frayadjacent is offline
Old 05-16-2009, 01:36 PM   #166
smartcargal
this is great link..
smartcargal is offline
Old 06-30-2009, 05:19 PM   #167
jjones811@hotmail.com
I have been getting bad MPG since the 40,000 maintenance check and concommital tire replacement (Pirelli P4 88T tires if that makes a difference). It dropped from 53 MPG to about 46 MPG, Toyota dealership is saying I should have gotten their Michellin tires, and gone with their tire pressure recommendations. The tire store said type of tire doesn't matter, just as long as it is the same size. Toyota manufacturer recommendations (found on the door jam) recommend 35-33 tire pressure; Tucson, Az. dealership recommends 38-38, and the chat line recommendations for tire pressure are even higher.
Any recommendations?
Thanks- J. Jones
jjones811@hotmail.com is offline
Old 06-30-2009, 05:26 PM   #168
morpheusx
Professor Chaos
morpheusx's Avatar
Thanks- J. Jones
38 all around is the start of getting better results, if the roads are smooth in your area I would try 44fr 42rear. Personally though I run about 50front 48rear on Goodyear TripleTreds in the slightly wider size and I have been hovering around 58 - 62 MPG. Expect about a 5 MPG loss though if you are needing to run the A/C as I expect you most likely do in AZ.
morpheusx is offline
mpg, owner, read
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-fuel-economy/14701-new-owner-want-mpg-help-read-first.html
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 05-12-2009 08:26 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 05-05-2009 02:22 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 04-26-2009 07:37 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 04-04-2009 01:41 AM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 03-27-2009 10:02 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 03-24-2009 07:55 AM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 03-18-2009 09:57 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 03-16-2009 08:02 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 03-09-2009 07:45 AM
Dodge Stratus Rear Shock Repair, Dodge Stratus Problems, Dodge Stratus Recalls - Kawasakiklx This thread Refback 03-08-2009 08:46 AM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 03-05-2009 10:51 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 03-04-2009 04:35 PM
Why is the gas mileage on 07 camry hybrid so low? - Yahoo! Answers This thread Refback 02-26-2009 02:24 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 02-24-2009 06:58 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 02-18-2009 02:41 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 02-18-2009 01:52 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 02-17-2009 08:53 PM
28-31 mpg - GreenHybrid - Hybrid Cars This thread Refback 11-23-2008 02:26 AM
"Question Of The Day: Your Mileage Will Vary" Strategies for Smart Car Buyers This thread Refback 08-14-2008 10:50 PM
New owner? Want MPG help? Read this first. This thread Refback 07-17-2008 04:59 PM
Why is the gas mileage on 07 camry hybrid so low? - Yahoo! Answers This thread Refback 05-27-2008 02:06 PM
Yahoo! Canada Answers - Why is the gas mileage on 07 camry hybrid so low? This thread Refback 03-03-2008 12:16 PM
Hybrid Cars - Page 11 - ConstantChatter This thread Refback 01-27-2008 08:32 PM
Hybrid Cars - Page 11 - ConstantChatter This thread Refback 01-27-2008 04:10 PM
Strategies for Smart Car Buyers - Question Of The Day: Your Mileage Will Vary This thread Refback 01-23-2008 12:06 PM
Strategies for Smart Car Buyers - Question Of The Day: Your Mileage Will Vary This thread Refback 01-22-2008 01:26 PM
Quick - What's your MPG read right now? vintagebob Gen II Prius Main Forum 242 03-26-2008 09:50 AM
It's all in how you read the stats genalex Prius and Hybrid News 6 08-23-2006 03:40 PM
Owner's Manual - Do you read it? Charles Suitt Gen II Prius Main Forum 11 12-02-2005 08:49 PM
Prius owner would pay the same fuel tax as a Hummer owner IsrAmeriPrius Prius and Hybrid News 8 11-17-2004 02:35 PM
