This is a discussion on Strange fillup within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; HI, I went to fill my "Gumdrop" last night. I always fill on the lowest automatic setting and then round ...
Strange fillup
Old 02-17-2006, 07:52 AM   #1
Walker1
Walker1's Avatar
HI, I went to fill my "Gumdrop" last night. I always fill on the lowest automatic setting and then round up to the next dollar.
However, this time the pump shut. When I went to round up to the next $ I could only put 20 cents more in. The tank was full.
My manual milege equated to 43 MPG, computer said 52 MPG. I figure for whatever reason the pump filled the tank almost to the top. I have read that a Prius tank holds between 1 & 2 gallons after the first click shutoff.
Has anyone else experienced this? All other factors were the same. Thanks.
2008 Red Barcelona Prius, Pkg. 2 And dealer installed leather seats. Current milege is 13,000.
2006, Black, Pkg. 1, Tinted windows, Leather wrap wheel cover, leather arm rest cover. 41,000 Miles, Bought on 1/7/06. Lifetime fuel average: 52.4 MPG. As of 7/8/08 NO defects or any other problems. This car has NEVER been to the dealer for any reason. I run the A/C on 68-70 degrees almost all year long.
Note: Both Prius's have NEVER been to a dlr. for any defects or repairs to date.
Walker1 is offline
Old 02-17-2006, 08:37 AM   #2
Betelgeuse
Betelgeuse's Avatar
[snapback]211034[/snapback]
The statement that the "Prius tank holds between 1 & 2 gallons after the first click shutoff" is incorrect. The amount of additional gas that you can "squeeze" into the tank varies widely, based on the pump, the air temperature, the speed at which you fill, the mood of Bill Merchant, etc.
I've had times where I knew the tank could take more gas, but I couldn't make the pump put any more in. I've had times where I put in ~3 gallons after the click. Then, there was the time where I had the pump going on the "first pump" (i.e BEFORE the click-off) and, after I pulled the nozzle out, gas starting coming back OUT of the tank (I'd clearly overfilled it, but without any effort to top-off). It must have spit a cup or two of gas back onto the pavement. As someone else posted here, the Toyota web site points out that ONE CUP of spilled gas releases the same number of hydrocarbons into the atmosphere as you do in driving the Prius 8000 MILES.
The short version of this story is that TOPPING OFF ISN'T WORTH IT. I understand the draw of doing it (i.e. trying to get a "great tank"), but we all live close enough to gas stations that we really don't need to worry about getting every last milliliter of gas into the tank.
Betelgeuse is offline
Old 02-17-2006, 09:23 AM   #3
richard schumacher
Destination: Eschaton
Why?
richard schumacher is offline
Old 02-17-2006, 11:39 AM   #4
Walker1
Walker1's Avatar
Originally posted by richard schumacher@Feb 17 2006, 09:23 AM
Why?
[snapback]211060[/snapback]
For consistency & accurate milege. If I do the same fillup the same way each time I most always get an accurate MPG. I never try to overfill the tank.
Walker1 is offline
Old 02-17-2006, 12:12 PM   #5
maggieddd
maggieddd's Avatar
[snapback]211155[/snapback]
how does rounding up to the next dollar give you consistency & accurate milage?
maggieddd is offline
Old 02-17-2006, 12:18 PM   #6
Walker1
Walker1's Avatar
[snapback]211170[/snapback]
It was something someone on this forum suggested to me. He is a senior member.
Walker1 is offline
Old 02-17-2006, 12:22 PM   #7
maggieddd
maggieddd's Avatar
[snapback]211174[/snapback]
is this a joke?
Old 02-17-2006, 12:33 PM   #8
ScottY
ScottY's Avatar
If you always round up to the next dollar, ur calculation will always be incorrect. Let's say one time the pump stopped at $10.10. You keep filling up till $11. Next time the pump stopped at $10.99, you filled it up to $11. How do you keep an consistant measurement? This might explain why ur calculated MPG (43) is so different than the MFG read out (52).
Just stop whenever the pump clicks.
ScottY is offline
Old 02-17-2006, 12:47 PM   #9
maggieddd
maggieddd's Avatar
[snapback]211180[/snapback]
that's exactly what I asked.
So I assumed this must be a joke
Old 02-17-2006, 01:28 PM   #10
Walker1
Walker1's Avatar
I guess I'll try that next time. Is that how you check your MPG?
Walker1 is offline
Fillup issues TomTech Gen II Prius Care, Maintenance and Troubleshooting 1 06-10-2007 04:54 PM
First Fillup NoVaSnow Gen II Prius Main Forum 6 05-24-2006 12:25 AM
3rd Fillup Walker1 Gen II Prius Fuel Economy 0 01-28-2006 03:17 PM
Strange Fillup? MNPrius Gen II Prius Fuel Economy 5 11-04-2005 08:08 AM
Wierd Fillup exces6 Gen II Prius Main Forum 10 03-15-2005 10:22 PM
